[GRASS-user] [Qgis-user] Python modules problems after last OSX GIS updates
Hi there
Sorry, my mistake
It’s the Dakota GIS Team who’s using a VM. I’d just read that and it got stuck in my head.
I re-checked it today and William’s binaries are working fine (python complains about LucidaGrande fonte, but that’s it):
2014-07-01 09:01:14.232 Python[21856:d0b] CoreText performance note: Client called CTFontCreateWithName() using name “.Lucida Grande UI” and got font with PostScript name “.LucidaGrandeUI”. For best performance, only use PostScript names when calling this API.
The problems are actually with Michael Barton’s GRASS-7.0 binaries. (I want to look at the global MOLA dataset, so went with v7.0 since it already has the planetary bodies listed on the Location wizard)
In it, I can import matplotlib, but this:
import matplotlib.pyplot as plt
gives me this:
File “”, line 1, in
File “/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/pyplot.py”, line 24, in
import matplotlib.colorbar
File “/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/colorbar.py”, line 27, in
import matplotlib.artist as martist
File “/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/artist.py”, line 8, in
from transforms import Bbox, IdentityTransform, TransformedBbox,
File “/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/transforms.py”, line 35, in
from matplotlib._path import (affine_transform, count_bboxes_overlapping_bbox,
ImportError: dlopen(/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/_path.so, 2): no suitable image found. Did find:
/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/_path.so: mach-o, but wrong architecture
sorry about the confusion
best
Carlos
On Mon, Jun 30, 2014 at 10:08 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
  • Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
Can’t stop the signal.
On Mon, Jun 30, 2014 at 7:57 PM, William Kyngesburye <woklist@kyngchaos.com> wrote:
What are the errors? Do you have simple examples I can try? I updated matplotlib and GDAL a month ago and this is the first I’ve heard of problems. I am not packaging with a virtual machine.
I did hear about GRASS problems. There are font warnings due to a slip in wxPython bugfixing - fixed for wx Carbon but not wx Cocoa. I am now using wxPython 3 Cocoa, and I read that there were fixes in GRASS for that version, but maybe there are other problems, or it may be an OS X thing.
Regarding wxPython3 Cocoa, there is still a lot of problems. I found several tickets on wxWidgets which we are affected by and only for some of them there is a workaround. WxGUI works only to certain extent, but there are problems with dialog modality, map selection widget, toolbars and other pretty serious things. On the other hand, wxnviz seems to work pretty well, although switching back to 2D mode, makes the GUI unresponsive which is bug in a notebook widget, not wxNviz.
On Jun 30, 2014, at 3:28 PM, Carlos Grohmann <carlos.grohmann@gmail.com> wrote:
Hello, apologies for cross-posting but this might be happening to other users
After installing the latest packages updates from William Kyngesburye on OSX 10.9 Mavericks, I’m getting lots of errors, both in Matplotlib and GDAL. From what I could see, that all return the “mach-o, but wrong architecture” error, so this might be related to William’s recent setup for packaging using a virtual machine.
I’m also getting the some errors with wxpython running GRASS 6.4.4
Unfortunately for me, Matplotlib is pretty much essential, so I’m hoping this issues get fixed soon.
sorry, no idea about this
Anna
best
Carlos
Qgis-user mailing list
Qgis-user@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
William Kyngesburye <kyngchaosatkyngchaosdotcom>
http://www.kyngchaos.com/
“Those people who most want to rule people are, ipso-facto, those least suited to do it.”
  • A rule of the universe, from the HitchHiker’s Guide to the Galaxy
grass-user mailing list
grass-user@lists.osgeo.org
Is that within the GRASS GUI? That makes sense since Michael is probably still using the old Carbon wxpython, which has to run in 32 bit mode. My matplotlib is 64 bit only. I have problems getting it to compile both 32 and 64 bits.
On Jul 1, 2014, at 7:21 AM, Carlos Grohmann <carlos.grohmann@gmail.com> wrote:
Hi there
Sorry, my mistake
It's the Dakota GIS Team who's using a VM. I'd just read that and it got stuck in my head.
I re-checked it today and William's binaries are working fine (python complains about LucidaGrande fonte, but that's it):
2014-07-01 09:01:14.232 Python[21856:d0b] CoreText performance note: Client called CTFontCreateWithName() using name ".Lucida Grande UI" and got font with PostScript name ".LucidaGrandeUI". For best performance, only use PostScript names when calling this API.
The problems are actually with Michael Barton's GRASS-7.0 binaries. (I want to look at the global MOLA dataset, so went with v7.0 since it already has the planetary bodies listed on the Location wizard)
gives me this:
  File "<stdin>", line 1, in <module>
  File "/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/pyplot.py", line 24, in <module>
  File "/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/colorbar.py", line 27, in <module>
  File "/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/artist.py", line 8, in <module>
    from transforms import Bbox, IdentityTransform, TransformedBbox, \
  File "/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/transforms.py", line 35, in <module>
best
Carlos
What are the errors? Do you have simple examples I can try? I updated matplotlib and GDAL a month ago and this is the first I've heard of problems. I am not packaging with a virtual machine.
> After installing the latest packages updates from William Kyngesburye on OSX 10.9 Mavericks, I'm getting lots of errors, both in Matplotlib and GDAL. From what I could see, that all return the "mach-o, but wrong architecture" error, so this might be related to William's recent setup for packaging using a virtual machine.
> I'm also getting the some errors with wxpython running GRASS 6.4.4
> Unfortunately for me, Matplotlib is pretty much essential, so I'm hoping this issues get fixed soon.
Anna
> best
> Carlos
> - Digital Terrain Analysis | GIS | Remote Sensing -
> ________________
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
________________
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
I think you are right.
importing only matplotlib works, but pyplot doesn’t, so it should related to wxpython.
best
Carlos
On Tue, Jul 1, 2014 at 10:20 AM, William Kyngesburye <woklist@kyngchaos.com> wrote:
Hi there
Sorry, my mistake
gives me this:
File “”, line 1, in
best
Carlos
Anna
best
Carlos
“Time is an illusion - lunchtime doubly so.”
  • Ford Prefect
