[GRASS-user] Query by mouse
Dear GRASSusers,
I'm looking for a way for a multiple query with mouse on GRASS6.2 or 6.3.
The Query button in the Map Display of Gis Manager returns the values of the
active (highlighted) map only, even if more maps are displayed.
The r.what command accessed through Raster > Query by coordinate(s) requires
to define the coordinates (even if this is defined as optional) and the
mouse can not be used.
The d.what.rast (and d.where)can be used in command line mode (lower part of
the Output window)but requires the opening of a new external monitor
(Otherwise: No graphics device selected).
Accidentally I discovered a strange and atypical way for a multiple query.
I highligh the name of a map in the map list of the Gis Manager. In the
panel 'Display raster maps' I manually insert the names of the other maps to
query, separated by commas. At this point the Query button displays the
content of all specified maps. This works but doesn't seem a neat solution.
Does anybody suggest a better way for a multiple query?
Thanks in advance
Aldo Clerici
Your workaround is pretty neat. I don't know of any other at the moment
without some reprogramming of the UI. It's a nice idea though.
Michael
On 2/13/07 4:38 AM, "Aldo Clerici" <alcl01@ipruniv.cce.unipr.it> wrote:
Dear GRASSusers,
Thanks in advance
Aldo Clerici
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
6.3. The Query button in the Map Display of Gis Manager returns the
values of the active (highlighted) map only, even if more maps are
displayed.
requires to define the coordinates (even if this is defined as
optional) and the mouse can not be used.
part of the Output window)but requires the opening of a new external
monitor (Otherwise: No graphics device selected).
query. I highligh the name of a map in the map list of the Gis
Manager. In the panel 'Display raster maps' I manually insert the
names of the other maps to query, separated by commas. At this point
the Query button displays the content of all specified maps. This
In an xmon if you overlay multiple raster maps,
G63> d.mon x0
G63> d.rast elevation.dem
G63> d.rast -o slope
G63> d.rast -o geology
then d.what.rast will give all three:
G63> d.what.rast -t
594278.69230769:4919478.84615385:1
elevation.dem@PERMANENT :1554:
slope@PERMANENT, quant :22:
slope@PERMANENT, actual :22.878124:23 degrees
geology@PERMANENT :5:limestone
The query in gis.m only queries the currenly selected map, even though
r.what (which it calls) has the capacity to query multiple maps at the
same time. Your "," trick works from that.
Another command prompt way using d.where:
G63> d.where | r.what in=elevation.dem,slope,geology
Hamish
it wuold be trivial to add possibility to select multiple maps in
gis.m, but it will need to change every place where one layer is
assumed. This may be too much. Unless somebody provides a working
patch, this should be left for wx GUI.
Aldo Clerici, You can open a wish (featire request) at GRASS bug
tracker so it will not be lost.
Maris.
2007/2/14, Hamish <hamish_nospam@yahoo.com>:
> displayed.
G63> d.mon x0
G63> d.what.rast -t
Hamish
grassuser mailing list
grassuser@grass.itc.it
