Vincent Bainwrote:
>> > Thank you Markus, good news !
>> > how long has it been implemented ?
Markus Metz wrote:
>> The option to snap boundary vertices has been there ever since. The
>> suggestion of a reasonable (assuming floating point rounding errors)
>> threshold for snapping has been added 3 weeks ago, on April 19th.
>> BTW, if the input polygons are supposed to not overlap each other, the
>> number of centroids should be identical to the number of input
>> polygons (needs to be added to the manual).
Nikos Alexandris:
> I tried to import USGS' (2011) Global Mangroves map:
> # stuff copied from the map's *latest* history
> v.in.ogr dsn="/geo/geodata/mangroves/usgs_mangroves/usgs_mangroves2.shp"
> output="global_mangroves_usgs_2011" min_area=0.0001 snap=0.000000000000001
> 2018421 input polygons
> Total area: 1.47005E+11 (2750605 areas)
> Overlapping area: 5.32085E+09 (41540 areas)
> Area without category: 9.25489E+09 (773734 areas)
> Twice the "error" message was like (even after I, by mistake, imported
> with snap=1e-15):
> Ended with an "error while impoting, try to import with snap 1e-14"
> This means that there are still errors in the map, right?
Markus Metz wrote:
I assume the global mangroves map should not have overlapping
polygons, therefore as long as there are overlapping areas and/or the
number of centroids is not equal to the number of input polygons, more
cleaning is needed.
Unfortunately it seems there are overlapping polygons. All import attempts so
far report many overlapping polygons, e.g.:
- snap 1e-15 (number of overlapping areas shown above)
centroids=1976871
areas=2750605
- snap 1e-8: "WARNING: 41540 areas represent more (overlapping) features..."
Number of centroids: 1976871
Number of areas: 2750605
- snap 1e-7: "WARNING: 41539 areas represent more (overlapping) features..."
Number of centroids: 1976845
Number of areas: 2750579
- snap 1e-6: "WARNING: 41538 areas represent more (overlapping) features..."
Number of centroids: 1976634
Number of areas: 2750368
Complete v.in.ogr's outputs copy-pasted below. The number of imported areas
drops with snap=1e-7 and after. And it takes quite some time in my machine to
import this data set. If it is the case of so many overlapping polygons,
maybe USGS folks should be notified?
I will search the respective documentation tonight to find stuff related to
minimum area extent -- maybe this can help (?).
Thanks, Nikos
# snap=1e-8
v.in.ogr
dsn="/geo/geodata/mangroves/global_mangroves_usgs_2011/usgs_mangroves2.shp"
output="global_mangroves_usgs_2011_08" min_area=0.0001 snap=0.00000001
Counting polygons for 1432891 features (OGR layer <usgs_mangroves2>)...
100%
Importing 1432891 features (OGR layer <usgs_mangroves2>)...
100%
Building topology for vector map
<global_mangroves_usgs_2011_08_tmp@PERMANENT>...
Registering primitives...
2505416 primitives registered
41179836 vertices registered
Number of nodes: 2384470
Number of primitives: 2505416
Number of points: 0
Number of lines: 0
Number of boundaries: 2505416
Number of centroids: 0
Number of areas: -
Number of isles: -
Cleaning polygons
Snapping boundaries (threshold = 1.000e-08)...
Reading features...
Snap vertices Pass 1: select points
100%
Snap vertices Pass 2: assign anchor vertices
100%
Snap vertices Pass 3: snap to assigned points
100%
Breaking polygons...
Breaking polygons (pass 1: select break points)...
100%
Breaking polygons (pass 2: break at selected points)...
100%
Removing duplicates...
100%
Breaking boundaries...
100%
100%
Cleaning boundaries at nodes...
100%
Merging boundaries...
100%
Removing dangles...
100%
Building areas...
100%
2750605 areas built
1278400 isles built
Number of nodes: 3463039
Number of primitives: 10456763
Number of points: 0
Number of lines: 0
Number of boundaries: 10456763
Number of isles: 1278400
Removing bridges...
100%
4133856 primitives registered
39140701 vertices registered
Building areas...
100%
2750605 areas built
1278400 isles built
Attaching islands...
100%
Number of nodes: 2661651
Number of primitives: 4133856
Number of points: 0
Number of lines: 0
Number of boundaries: 4133856
Finding centroids for OGR layer <usgs_mangroves2>...
100%
Writing centroids...
100%
WARNING: 41540 areas represent more (overlapping) features, because
polygons overlap in input layer(s). Such areas are linked to more
than 1 row in attribute table. The number of features for those
areas is stored as category in layer 2
Copying features...
100%
<global_mangroves_usgs_2011_08@PERMANENT>...
6110727 primitives registered
41117572 vertices registered
Building areas...
100%
2750605 areas built
1278400 isles built
100%
Attaching centroids...
100%
Number of primitives: 6110727
Number of points: 0
Number of lines: 0
WARNING: Errors were encountered during the import
Try to import again, snapping with 1e-07: 'snap=1e-07'
# snap=1e-7
v.in.ogr
output="global_mangroves_usgs_2011_07" min_area=0.0001 snap=0.0000001
100%
100%
<global_mangroves_usgs_2011_07_tmp@PERMANENT>...
Number of points: 0
Number of lines: 0
Number of areas: -
Number of isles: -
Cleaning polygons
Snapping boundaries (threshold = 1.000e-07)...
Reading features...
100%
100%
100%
100%
100%
100%
100%
100%
100%
100%
Removing dangles...
100%
Building areas...
100%
2750579 areas built
1278397 isles built
Number of nodes: 3463450
Number of primitives: 10457376
Number of points: 0
Number of lines: 0
Number of boundaries: 10457376
Number of isles: 1278397
Removing bridges...
100%
4133745 primitives registered
39140346 vertices registered
Building areas...
100%
2750579 areas built
1278397 isles built
100%
Number of nodes: 2661563
Number of primitives: 4133745
Number of points: 0
Number of lines: 0
Number of boundaries: 4133745
100%
100%
WARNING: 41539 areas represent more (overlapping) features, because
Total area: 1.47005E+11 (2750579 areas)
Overlapping area: 5.32085E+09 (41539 areas)
Copying features...
100%
<global_mangroves_usgs_2011_07@PERMANENT>...
6110590 primitives registered
41117191 vertices registered
Building areas...
100%
2750579 areas built
1278397 isles built
100%
100%
Number of primitives: 6110590
Number of points: 0
Number of lines: 0
Try to import again, snapping with 1e-06: 'snap=1e-06'
# snap=1e-6
v.in.ogr
output="global_mangroves_usgs_2011_06" min_area=0.0001 snap=0.000001
100%
100%%
<global_mangroves_usgs_2011_06_tmp@PERMANENT>...
Number of points: 0
Number of lines: 0
Number of areas: -
Number of isles: -
Cleaning polygons
Snapping boundaries (threshold = 1.000e-06)...
Reading features...
100%
100%
100%
100%
100%
100%
100%
100%
100%
100%
Removing dangles...
100%
Building areas...
100%
2750368 areas built
1278375 isles built
Number of nodes: 3466918
Number of primitives: 10463204
Number of points: 0
Number of lines: 0
Number of boundaries: 10463204
Number of isles: 1278375
WARNING: Number of incorrect boundaries: 11
Removing bridges...
100%
4132751 primitives registered
39137038 vertices registered
Building areas...
100%
2750368 areas built
1278377 isles built
100%
Number of nodes: 2660760
Number of primitives: 4132751
Number of points: 0
Number of lines: 0
Number of boundaries: 4132751
Number of isles: 1278377
100%
100%
WARNING: 41538 areas represent more (overlapping) features, because
Total area: 1.47005E+11 (2750368 areas)
Overlapping area: 5.32085E+09 (41538 areas)
Copying features...
100%
<global_mangroves_usgs_2011_06@PERMANENT>...
6109385 primitives registered
41113672 vertices registered
Building areas...
100%
2750368 areas built
1278377 isles built
100%
100%
Number of primitives: 6109385
Number of points: 0
Number of lines: 0
Try to import again, snapping with 1e-05: 'snap=1e-05'
