I need to query raster values around a city for different angles. The result I am aiming at should be the amount of landcover surrounding the city within 10 degrees angles and different distances to the city.
So far I tried r.buffer and v.buffer but that are not providing what I am lookin for. Using r.mapcalc and addressing each pixel separately would be an option but I hope that GRASS combined with perhaps PGSQL and Postgis functions provides an easier way to achieve that.
I would highly appreciate any hints how to derive buffers for specific angles only.
kind regards, Tim
P.S.: using GRASS 6.4.1. under Windows, QGIS 1.6.0 and the newest R version
in years past I had a version of r.los for GRASS 5.0 where instead
of reporting the vertical angle to the source point I had it
report horizontal compass heading. I'm sure it's on an old hard
drive somewhere, but in hindsight using r.mapcalc and some simple
trig would be a heck of a lot easier and more efficient than
anything else. No other tools are needed beyond that one amazing
module.
#spearfish
g.region -d
g.region -c
center easting: 599490.000000
center northing: 4920855.000000
worked pretty good for my purposes. But as I am a beginner in GRASS I need to ask what the $ sign stands for. Because when I applied your solution with the $-sign and just copied it the resulting maps were rather coarse in resolution. So I tried and left the $ sign away. The result was a map in the same resolution as the original map.
Thanks for quick help!
Cheers Tim
Am 31.05.2011 12:33, schrieb Hamish:
module.
#spearfish
g.region -d
g.region -c
