[GRASS-user] Question about deprecacted EPSG codes
I was trying to create a new location from the command line with:
g.proj -c location=NB_Stereo epsg=2036
but received a seg fault. Checking the epsg code list in the Grass startup epsg code browser, I see that code 2036 for New Brunswick Double Stereographic is deprecated. Is this the source of the g.proj -c seg fault, or is the seg fault unrelated? A second question is why are some epsg codes deprecated in the first place - what does deprecation mean in this sense? Does it imply that I won't be able to use this projection/datum combination in future versions of Grass?
~ Eric.
Patton, Eric wrote:
Eric,
The EPSG folks deprecate a code when they realize there is a serious error
in the definition (proper name, parameters, etc). The deprecated code and
it's dependencies remains in the database, but the fixed version is created
as a new code and people are encouraged to use that.
I don't see any reason a code being deprecated should cause g.proj to crash.
This is likely due to something else.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | President OSGeo, http://osgeo.org
Hello Eric
On Tue, 20 Feb 2007, Patton, Eric wrote:
Possibly indirectly related (see below) but the direct cause is a bug in the recent changes I made to g.proj, which I have now fixed in CVS. The problem was there were datum parameters but no datum name, but the code assumed if there were parameters there must be a name.
I think it is what the maintainers of the EPSG database do when they make a slight change to an entry in the database - they give it a new number put keep the old one and mark it deprecated. But AFAIK it stays there forever for backwards compatibility.
I would hazard a guess that the "improvement" that has caused 2036 to be superceded might be the addition of a datum name, but no idea really.
Anyway, yes it will continue to work, and the bug is now fixed.
Paul
PS your e-mail contained some really long lines which made it awkward to quote bits of it - is there any chance you could set your mail client to wrap lines at 72 characters or something similar?
