[GRASS-user] Question about MAPSET permissions with a GRASS script
List:
I have written a GRASS shell script for Linux that works perfectly well except for one thing. Anyone who runs it from their login ID must be able to run the script, which they initiate manually. The MAPSET is generic, called 'oper' — we have an 'oper' Linux login. What happens is that unless I login or 'su' to 'oper', the script fails with:
ERROR: MAPSET oper — permission denied
etc.
The process involves (among other things) reading in point data using v.in.ascii and spatially interpolating it to a raster.
I have tried a number of things to set the GRASS permissions to allow universal access to the 'oper' MAPSET as well as trying to export the USER variable, etc. Nothing seems to work. Does anyone have a suggestion? I'm trying to avoid requiring everyone to create their own login/MAPSET and have the resulting files (which we want to retain as an archive) scattered around in different MAPSETS.
Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams@noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
generic, called 'oper' � we have an 'oper' Linux login. What happens is
ERROR: MAPSET oper � permission denied
etc.
suggestion?
GRASS requires that you own the current mapset.
If you want to avoid this, you need to remove the check from
G__mapset_permissions() in lib/gis/mapset_msc.c.
Glynn,
Thanks, but I don't want to break that feature in GRASS. I suppose I was hoping that someone might have a suggestion as to how I might set an environment variable or do something in my script that would set the login ID to 'oper' that GRASS would recognize as legitimate. Someone I work with suggested that some use of 'expect' might work; so, I am playing with that approach.
Tom
----- Original Message -----
Date: Sunday, October 28, 2007 11:12 pm
Subject: Re: [GRASS-user] Question about MAPSET permissions with a GRASS script
perfectly well
be
is
happens is
> etc.
using
allow
the
> suggestion?
> > etc.
> > suggestion?
You could probably use expect to script logging in as "oper".
The ownership check is performed using the process' UID, so you need
to actually become the "oper" user by some means, whether by logging
in, su, sudo, or a setuid executable.
