Thank’s for the replay Hermann,
this is not the case AFAIK because i generated the map using r.mapcalc
with region and MASK properly set …
roy
Da: peifer
Data invio: giovedì 11 settembre 2014 13.31
A: grass-user@lists.osgeo.org
m roy wrote
r.info min = 0 max = 1
r.stats
0 775…
- 805….
r.stats honours the current region, r.info doesn’t.
If your map’s data area would be in Europe and your current region is by
mistake defined somewhere in the middle of Canada: r.stats would report all
values to be NULL.
Hermann
View this message in context: http://osgeo-org.1560.x6.nabble.com/question-about-r-info-tp5161293p5161299.html
grass-user mailing list
