[GRASS-user] Question about the use of d.vect.thematic
All:
I am trying to use d.vect.thematic to create a thematic map where the vector polygons are filled with a color dependent on an attribute value, swe, which is of type 'real'. I am using sqlite as the db driver. The swe attribute was added to my vector map using v.db.join, which worked fine. I can query the map and see that the swe values are correct.
However, when I use d.vect.thematic, I get the following error:
Column <swe> is of type <real> which is not numeric.
I don't understand; I guess there are subtle nuances with these data type considerations which I don't yet appreciate. When I created my sqlite db and table, should I have read-in the data as a different type? If so, what?
Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams@noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
error:
probable bug in d.vect.thematic which only know integer and
double precision.
my advice if you have less than 30,000 area features is to use
the new v.colors scripts to add a new GRASSRGB column with
colors, then use 'd.vect -a'. Maybe it is possible to use
d.vect's new zcolor= option, but that is more for points data
than areas.
of course v.colors suffers from the same lack of imagination
and so will need an edit to work with "REAL" types.
look for a line like this:
(v.colors, but d.vect.thematic is similar)
elif [ "$NCOLUMN_TYPE" != "INTEGER" ] && [ "$NCOLUMN_TYPE" != "DOUBLE PRECISION" ] ; then
    g.message -e "Column <$GIS_OPT_COLUMN> is not numeric"
    exit 1
fi
and try adding
  && [ "$NCOLUMN_TYPE" != "REAL" ]
to the test. (edit to match local conditions)
Hamish
Hamish,
I made the code changes in the scripts (v.colors & d.vect.thematic), adding:
in the tests and that worked perfectly. Thanks for your help!!
Tom
error:
double precision.
than areas.
    exit 1
fi
and try adding
Hamish
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
