[GRASS-user] Question about v.generalize: nothing is removed when using douglas_reduction?
I'm trying to use v.generalize method=douglas_reduction, but the output has
the same number of vertices as the input map and I don't know why it is not
being simplified.
In case it helps, the input map is:
v.info JR_2001SubSetLines
| Layer: JR_2001SubSetLines
| Mapset: generalize
| Database: /home/eric
| Title:
| Map scale: 1:1
| Map format: native
| Name of creator: eric
| Organization:
| Source date: Tue Jun 9 16:12:20 2009
| Type of Map: vector (level: 2)
| Number of points: 0 Number of areas: 0
| Number of lines: 11758 Number of islands: 0
| Number of boundaries: 0 Number of faces: 0
| Number of centroids: 0 Number of kernels: 0
| Map is 3D: Yes
| Number of dblinks: 0
| Projection: Lambert Conformal Conic
| N: 251271.999 S: 250940.025
| E: 913711.894 W: 913272.031
| B: -1.288 T: 14.218
| Digitization threshold: 0
| Comments:
when I run
v.generalize input=JR_2001SubSetLines output=JR_2001_SSL_reduc_50
method=douglas_reduction threshold=0 reduction=50 type=line --o
I get
Number of nodes: 11758
Number of primitives: 11758
Number of points: 0
Number of areas: 0
Number of isles: 0
Number of vertices was reduced from 23516 to 23516 [100%]
Adding the -r flag to remove small lines gives the same result.
Using method=douglas without the -r flag gives the same result.
Using method=douglas with the -r flag works, but I would like to know what
I'm doing wrong and how to use the reduction feature.
Eric
Eric Hardin
View this message in context: http://n2.nabble.com/Question-about-v.generalize%3A-nothing-is-removed-when-using--douglas_reduction--tp3068397p3068397.html
