[GRASS-user] Question on Importing E$RI Grid DEM
   I thought I had a saved thread from this list on this subject, but
grepping my mail subdirectory I don't find it. Here's the situation:
   A set of 30m NED (National Elevation Database) DEMs as Lat/Long 1 degree
blocks. Data is in ARC GRID file format. Each directory has three
subdirectores: demgrid/, info/, and metadata/. The demgrid/ subdirectoy
contains: dblbnd.adf, hdr.adf, log, prj.adf, sta.adf, w001001.adf, and
w001001x.adf files.
   I thought I wanted to point the grass65 gui for raster->arc grid import to
the hdr.adf file, but I get errors and no import when I do that. Is there
another file that should be specified for proper import?
TIA,
Rich
to the hdr.adf file, but I get errors and no import when I do that. Is
there another file that should be specified for proper import?
   How strange. It works from the command line:
GRASS 6.5.svn (Nevada-ll):~/grassdata > r.in.gdal -e --overwrite
input=/home/rshepard/GIS/data/Nevada/DEM/area2/demgrid/hdr.adf
output=dem_area2 title='DEM NED Area 2'
Projection of input dataset and current location appear to match
  100%
r.in.gdal complete. Raster map <dem_area2> created.
Rich
2011/2/28 Rich Shepard <rshepard@appl-ecosys.com>:
Just a note: please keep the subject otherwise thread is broken and
it's hard to track it...
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Martin,
Does the postfix affect the thread? I thought it did not which is why many
of us add FIXED or SOLVED to close threads.
ops, it seems that postfix doesn't affect the thread [1]. Anyway
thread is broken at least in gmail web client. So sorry for the noise.
Martin
[1] http://lists.osgeo.org/pipermail/grass-user/2011-February/thread.html
