Dear Nikos.
After a long time I’m trying to reproduce a routine I have for doing intercallibratrion of DMSP 1992-2012 but for some reason It doesn’t work to me. I think is because the problem between the region of the layers 30 arc sec should resolution be from 0.008333333300000 to 0.008333333333333, i.e. exactly 30 arc-seconds? and the computational region be the same ? I got stuck on how to set it to work… from the side of the region setting.
However in addition my routing also has a for loop which does not work ok as well.
I would appreciate a lot of you can give it a look and tell me how to make it work…
Thanks a lot in advance
Kind regards,
Gabriel
complete routine for intercalliration of DSMP/OLS light stable product
import grass.script as gscript
import os
import os,glob
get working directory
print os.getcwd()
change working directory where raster files are
os.chdir(‘C:\Users\Gabriel\Documents\grassdata\lights’)
see files in directory
ls
import all raster files to grass — here is a kind of problem…???
for tif_file in glob.glob(“*.tif”):
new_rast = os.path.splitext(tif_file)[0]
grass.run_command(“r.in.gdal”, flags=“a”, input=tif_file, output=new_rast)
get info of one of the imported raster
r.info map=F121996
run intercalliration algorithm
i.nightlights.intercalibration image=F101992,F101993,F101994,F121994,F121995,F121996,F121997,F121998,F121999,F141997,F141998,F141999,F142000,F142001,F142002,F142003,F152000,F152001,F152002,F152003,F152004,F152005,F152006,F152007,F162004,F162005,F162006,F162007,F162008,F162009,F182010,F182011,F182012,F182013 suffix=c model=elvidge2014 -t
correct general region adjust to raster file — here the region is exactly 30 arc for the raster as I could see…
g.region raster=F121996
cerate a list of rasters in the mapset
rastlist=grass.read_command(“g.list”,type=“rast”).split()
rasters = grass.read_command(‘g.list’, type=‘raster’).splitlines()
os.chdir(‘C:\Users\Gabriel\Desktop\out’)
save rasters in mapset to file
for raster in rasters:
grass.run_command(‘r.out.gdal’, input=raster, output=raster + ‘.tiff’, format=‘GTiff’)
On Wed, Aug 22, 2018 at 10:06 AM Gabriel Cotlier <gabiklm01@gmail.com> wrote:
Dear Nikos,
Thanks a lot for your answer and the orientation.
The information and the link are very useful.
Kind regards,
Gabriel
On Wed, Aug 22, 2018 at 5:19 AM Nikos Alexandris <nik@nikosalexandris.net> wrote:
Dear Nikos and GRASS users,
I would like to ask if nonetheless the effect due to “stray light” the
i.landsat8.swlst code for split window is still applicable to Landsat 8
data and whether these error is specially visible on water bodies? and
whether band 10 is better than band 11 in terms of correction processing
for Level -1 data products?
Thanks a lot.
Kind regards,
Gabriel
Dear Gabriel,
for details and references, refer to
https://landsat.gsfc.nasa.gov/landsat-8-thermal-data-ghost-free-after-stray-light-exorcism/
Make sure you use the newest Level-1 Collection 1 Landsat 8 products.
I use i.landsat8.swlst
and plan to improve it further.
However, whether to prefer a Split-Window based approach, or another
Single-Channel one, depends on what you want to do. Think of spatial
extent and coverage of various land (cover) types, temporal extent
and more.
Thermal remote sensing is hard(er) also because it’s hard to get
ground-truth data sets so as to validate LST estimations.
Nikos
