[GRASS-user] Question on usage of v.to.rast
Greetings I have a vectorial (areas) and I want to convert to raster. In this vector each area is defined by New_ID that is a varchar and I want to create a raster where pixels inside each area must have a value. E.g. Area named A1 must be labelled as 1 and A2 as 2 and B1 as 3 and so on. Is this possible using v.to.rast?
Thanks
Luisa
Yes, but you’ll need a column in the vector attribute table with numeric values. THen run:
v.to.rast input_vect out= use=attr col=
If your attributes are in sqlite (not dbf) then I’m sure there are some SQL string functions you could use to get the integer values 1,2,3… out of the labels A1,B1,…
Micha Silver
Arava Development Co. +972-52-3665918
[http://surfaces.co.il](http://surfaces.co.il)
