[GRASS-user] Question on using r.resamp.stats
Greetings
a few messages ago I saw that someone advised to use r.resamp.stats to rescale for a coarser scale. Now I have one question:
In mapsetX I have a raster (named rasterA) with Spatial resolution 10 and 10.
Now in mapset Y my region spatial resolution is 50 and 50.
Question:
Having mapset Y active, If I apply r.resamp.stats to a raster map in a different mapset (mapset X) will it apply some kind of processing before it applies the r.resamp.stats? (like nearest neighbor or something)?
Thanks
Monica
10.
Question:
No.
It doesn't matter if the input map is in the current mapset or in a
different mapset. r.resamp.stats always reads its input map at the
map's native resolution.
