[GRASS-user] Question regarding grass.mapcalc
Greetings
I’m doing a Python script to calibrate a raster image. Since I need to do 3 different calculations I’m using a tempfile (tempL)
This is the code:
tempL = grass.read_command(“g.tempfile”, pid = “1”)
grass.mapcalc(“$L=$lmin+ (($lmax-$lmin)/($QCALmax-$QCALmin))* ($raster_file-$QCALmin)”, L=tempL, lmin=lmin, lmax=lmax, QCALmax=QCALmax, QCALmin=QCALmin, raster_file=raster_file)
Where tempL is a temporary, (lmin,lmax) are floats, QCALmax and QCALmin are int and raster_file is a raster map used as input.
And I get this:
syntax error, unexpected ‘/’, expecting NAME or STRING
Parse error
ERROR: An error occurred while running r.mapcalc
What is happening? I believe it has something to do with tempL. Maybe I’m not doing this right. Can anyone help me on this?
Thanks
Kim
Kim Besson wrote:
I'm doing a Python script to calibrate a raster image. Since I need to do 3
different calculations I'm using a tempfile (tempL)
This is the code:
     tempL = grass.read_command("g.tempfile", pid = "1")
    grass.mapcalc("$L=$lmin+ (($lmax-$lmin)/($QCALmax-$QCALmin))*
($raster_file-$QCALmin)", L=tempL, lmin=lmin, lmax=lmax, QCALmax=QCALmax,
And I get this:
syntax error, unexpected '/', expecting NAME or STRING
Parse error
What is happening? I believe it has something to do with tempL. Maybe I'm
g.tempfile returns the full pathname to a temporary file, not a map
name.
There isn't a module to generate temporary map names. A common
approach is to use the name of the script followed by ".tmp".
So your suggestion would be
rass.mapcalc(“$L=$lmin+ (($lmax-$lmin)/($QCALmax-$QCALmin)) ($raster_file-$QCALmin)”, L=tempL, lmin=lmin, lmax=lmax, QCALmax=QCALmax, QCALmin=QCALmin, raster_file=raster_file)
and at the end delete L file?
Thanks
Kim
2010/9/24 Glynn Clements <glynn@gclements.plus.com>
This is the code:
And I get this:
Parse error
name.
There isn’t a module to generate temporary map names. A common
approach is to use the name of the script followed by “.tmp”.
(($lmax-$lmin)/($QCALmax-$QCALmin)) ($raster_file-$QCALmin)", L=tempL,
My suggestion would be to replace:
with:
     tempL = myscript.tmp
Any temporary maps should be deleted upon termination. Use
atexit.register() to register a function which deletes any temporary
maps (if they exist). This will ensure that the maps get deleted
regardless of whether the script terminates normally or due to an
exception. Look at the scripts in 7.0 for examples.
