[GRASS-user] Question regarding r.lake?
Hi Maris et al.
I have a question about how r.lake works. I am using a DEM in UTM/11N with an elevation range from -49 to 153m and attempting to run r.lake against it to produce flooding layers. However, it will not produce a lake above 0.0m in elevation. I have tried a variety of elevations but they all only go to 0.0 meters. Am I doing something wrong?
Any help is appreciated.
Thank you.
John.
r.lake -n --overwrite --verbose dem=NBC.BaseModel.UTM11N.NAVD88.1_8m_v02.grdclip.flipped.nc@PERMANENT wl=5 lake=NBC_5 xy=478183.13, 3617526.21
Lake depth from -54.556332 to 0.000000
Lake area 171287640.635203 square meters
Lake volume -2715258244.183949 cubic meters
Volume is correct only if lake depth (terrain raster map) is in meters
(Tue Jan 31 08:18:01 2012) Command finished (39 sec)
(Tue Jan 31 08:19:40 2012)
r.lake -n --overwrite --verbose dem=NBC.BaseModel.UTM11N.NAVD88.1_8m_v02.grdclip.flipped.nc@PERMANENT wl=5.0 lake=NBC_5 xy=478183.13, 3617526.21
(Tue Jan 31 08:20:20 2012) Command finished (40 sec)
| Type of Map: raster Number of Categories: 255 |
| Data Type: FCELL |
| Rows: 8881 |
| Columns: 7987 |
| Total Cells: 70932547 |
| Projection: x,y |
| N: 3620275.4407297 S: 3602512.04121555 Res: 2.00015759 |
| E: 492504.21647433 W: 476529.78174709 Res: 2.00005443 |
| Range of data: min = -49.556332 max = 153.344849 |
| Data Description: |
| generated by r.in.gdal |
| Comments: |
| r.in.gdal input="/Users/hellyj/work/SLR002/data/NBC_Basemap/NBC.Base\ |
| Model.UTM11N.NAVD88.1_8m_v02.grdclip.flipped.nc" output="NBC.BaseMod\ |
| el.UTM11N.NAVD88.1_8m_v02.grdclip.flipped.nc" |
Cheers.
John Helly, University of California, San Diego / San Diego Supercomputer Center / Scripps Institution of Oceanography / 760 840 8660 mobile / stonesteps (Skype) / stonesteps7 (iChat) / http://www.sdsc.edu/~hellyj
