[GRASS-user] Questions: Clipping polygon layer to the outer boundary of another layer...
Hello:
I'm using v.in.ogr to clip a polygon set (in this case, county boundaries) to
the boundary of a (rectangular) raster image.
As far as I know, this is the only way to do this; I tried to create a new location
with the same boundaries and import the polygon shapefile into the location, but
clipping did not occur as expected.
In any case, v.in.ogr did not clip the 'boundary polygons' to the the edge of the
raster image, but included the entire polygon. Only excluded polygons completely
outside of the bounding box are clipped.
There MUST be a way to clip all polygons to the bounding box edge. Can any
one suggest a way?
The second edition of Netler's book discusses v.cutregion.sh and v.cutter methods,
but I cant find any evidence of these in GRASS 6.2.
Thanks for any help,
Rick Reeves
On Tue, Feb 12, 2008 at 10:21:50AM -0800, we recorded a bogon-computron collision of the <reeves@nceas.ucsb.edu> flavor, containing:
Hello:
to
location
location, but
of the
completely
one suggest a way?
methods,
Couldn't you do it with v.overlay?
Generate a polygon for the outline of your raster, then use the "and" operator
in v.overlay to select only those polygons that are inside the raster outline.
Doing so will cut the polygons that go outside the border.
See, for example,
  http://grass.itc.it/grass57/tutorial/vectoroverlay.html
but note that the figures for "or" and "and" operations on that page are
accidentally interchanged.
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1 http://kevan.org/brain.cgi?DDTNM
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
one trick, rational thinking, but when you're good and crazy, oooh, oooh,
oooh, the sky is the limit!" --- The Tick
On Tue, 2008-02-12 at 10:21 -0800, Rick Reeves wrote:
Hello:
boundaries) to
new location
location, but
Sorry for suggesting the obvious things (which you might have checked):
* if you want to clip based on a rectangular, did you try the "spatial"
parameter (or subregion in the GUI)? -- grab the extents of your
rectangular raster with r.info
edge of the
completely
one suggest a way?
v.cutter methods,
v.cutter is in grass5 -->
http://grass.itc.it/gdp/html_grass5/vector.html
Probably not ported in grass6 -- but it's not really necessary.
Rick Reeves
grass-user mailing list
grass-user@lists.osgeo.org
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
boundaries) to the boundary of a (rectangular) raster image.
a new location with the same boundaries and import the polygon
shapefile into the location, but clipping did not occur as expected.
edge of the raster image, but included the entire polygon. Only
excluded polygons completely outside of the bounding box are clipped.
I assume you used 'v.in.ogr spatial='. This works like v.select.
Can any one suggest a way?
v.in.region + v.overlay.
v.cutter methods, but I cant find any evidence of these in GRASS 6.2.
See the GRASS 5<->6 module porting list on the wiki:
  http://grass.gdf-hannover.de/wiki/GRASS_Module_Porting_List
and the GRASS 6.3 module synopsis:
  http://grass.ibiblio.org/gdp/grassmanuals/grass63_module_list.pdf
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
On 13/02/08 12:48, Hamish wrote:
Rick Reeves wrote:
I'm using v.in.ogr to clip a polygon set (in this case, county boundaries) to the boundary of a (rectangular) raster image.
Or v.in.region + v.select if you don't wan't to merge attribute tables.
Moritz
>> create a new location with the same boundaries and import the
>> polygon shapefile into the location, but clipping did not occur
>> as expected.
>> the edge of the raster image, but included the entire polygon.
>> Only excluded polygons completely outside of the bounding box
>> are clipped.
Hamish:
R:
H:
tables.
v.select will act the same way as 'v.in.ogr spatial=' (or a personal
favourite: 'v.in.ogr -r') which was what the original question was
hoping to avoid. ie v.select leaves features in or out, while v.overlay
both allows or omits features AND modifies any features which cross.
Hamish
Looking for last minute shopping deals?
Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
Thanks Hamish - This Worked Great.
Hey, while I am writing, can you recommend any GRASS methods for cleaning line feature
topology, besides v.clean? I am trying to repair a lot of missed connections in the USGS
NHP2 stream network data so that I can accurately compute stream distances with v.net.path.
At this point I may be forced to resort to Arc GIS Network Analyst to diagnose the problems,
but would MUCH rather use the GRASS tools.
A final question: Is anyone aware of a version of the NHP stream dataset that HAS been
cleaned and repaired to support distance calculations? This would not be a trivial task,
even for portions of the dataset.
Rick R
as expected.
are clipped.
Hamish:
R:
H:
tables.
Hamish
Looking for last minute shopping deals? Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
v.edit ? v.digit ?
Have you looked at the v.net.* tools ?
Moritz
