[GRASS-user] Questions on TGRASS; t.rast.gapfill , GRASS 71
Hi
I am trying to use the module “t.rast.gapfill” to fill the gaps in my temporal datasets. I have couple of doubts on getting my tasks done.
I am using GRASS 71 svn, latest.
##Q1:
In my temporal data , there are multiple continuous gaps. In this case, I am not getting the interpolated results. Please check the below work flow:
r.mapcalc expr=“map1 = 1” --o
r.mapcalc expr=“map2 = 3” --o
r.mapcalc expr=“map3 = 5” --o
r.mapcalc expr=“map4 = 7” --o
r.mapcalc expr=“map5 = 9” --o
t.register type=raster maps=map1 start=2012-08-20 end=2012-08-21 --o
t.register type=raster maps=map2 start=2012-08-22 end=2012-08-23 --o
t.register type=raster maps=map3 start=2012-08-25 end=2012-08-26 --o
t.register type=raster maps=map4 start=2012-08-29 end=2012-08-30 --o
t.register type=raster maps=map5 start=2012-09-03 end=2012-09-04 --o
t.create type=strds temporaltype=absolute output=mapT1 title=“test for all the gaps filled together” description=“test for all the gaps filled together”
t.register type=raster input=mapT1 maps=map1,map2,map3,map4,map5 --o
t.rast.list input=mapT1 columns=name,start_time,min,max
t.rast.list input=mapT1 method=gran
id|name|mapset|start_time|end_time|interval_length|distance_from_begin
map1@testtgrass|map1|testtgrass|2012-08-20 00:00:00|2012-08-21 00:00:00|1.0|0.0
None|None|None|2012-08-21 00:00:00|2012-08-22 00:00:00|1.0|1.0
map2@testtgrass|map2|testtgrass|2012-08-22 00:00:00|2012-08-23 00:00:00|1.0|2.0
None|None|None|2012-08-23 00:00:00|2012-08-24 00:00:00|1.0|3.0
None|None|None|2012-08-24 00:00:00|2012-08-25 00:00:00|1.0|4.0
map3@testtgrass|map3|testtgrass|2012-08-25 00:00:00|2012-08-26 00:00:00|1.0|5.0
None|None|None|2012-08-26 00:00:00|2012-08-27 00:00:00|1.0|6.0
None|None|None|2012-08-27 00:00:00|2012-08-28 00:00:00|1.0|7.0
None|None|None|2012-08-28 00:00:00|2012-08-29 00:00:00|1.0|8.0
map4@testtgrass|map4|testtgrass|2012-08-29 00:00:00|2012-08-30 00:00:00|1.0|9.0
None|None|None|2012-08-30 00:00:00|2012-08-31 00:00:00|1.0|10.0
None|None|None|2012-08-31 00:00:00|2012-09-01 00:00:00|1.0|11.0
None|None|None|2012-09-01 00:00:00|2012-09-02 00:00:00|1.0|12.0
None|None|None|2012-09-02 00:00:00|2012-09-03 00:00:00|1.0|13.0
map5@testtgrass|map5|testtgrass|2012-09-03 00:00:00|2012-09-04 00:00:00|1.0|14.0
Doing the gapfill:
t.rast.gapfill input=mapT1 base=gap
gap_10@testtgrass|gap_10|testtgrass|2012-08-21 00:00:00|2012-08-22 00:00:00|1.0|1.0
gap_11@testtgrass|gap_11|testtgrass|2012-08-23 00:00:00|2012-08-24 00:00:00|1.0|3.0
gap_11@testtgrass|gap_11|testtgrass|2012-08-24 00:00:00|2012-08-25 00:00:00|1.0|4.0
gap_12@testtgrass|gap_12|testtgrass|2012-08-26 00:00:00|2012-08-27 00:00:00|1.0|6.0
gap_12@testtgrass|gap_12|testtgrass|2012-08-27 00:00:00|2012-08-28 00:00:00|1.0|7.0
gap_12@testtgrass|gap_12|testtgrass|2012-08-28 00:00:00|2012-08-29 00:00:00|1.0|8.0
gap_13@testtgrass|gap_13|testtgrass|2012-08-30 00:00:00|2012-08-31 00:00:00|1.0|10.0
gap_13@testtgrass|gap_13|testtgrass|2012-08-31 00:00:00|2012-09-01 00:00:00|1.0|11.0
gap_13@testtgrass|gap_13|testtgrass|2012-09-01 00:00:00|2012-09-02 00:00:00|1.0|12.0
gap_13@testtgrass|gap_13|testtgrass|2012-09-02 00:00:00|2012-09-03 00:00:00|1.0|13.0
For example; between 2012-08-29 and 2012-09-03 there are 4 days of gap, but the gap filling is providing the same image at all the 4 gaps. It seems to be generating only one image between two valid temporal images, no matter how long the gap is!!
So is the gap filling will work only for one gap between 2 valid temporal images?
###2.
When I try to do gap fill with the “where” condition, I am getting no results in some cases.
For example when I try:
t.rast.gapfill input=mapT1 where=“start_time = ‘2012-08-21 00:00:00’” base=gap
No gaps found
OR when I try;
t.rast.gapfill input=mapT1 where=“start_time > ‘2012-08-20 00:00:00’” base=gap
It misses the first gap and fills the other gap, see below:
gap_8@testtgrass|gap_8|testtgrass|2012-08-23 00:00:00|2012-08-24 00:00:00|1.0|3.0
gap_8@testtgrass|gap_8|testtgrass|2012-08-24 00:00:00|2012-08-25 00:00:00|1.0|4.0
gap_9@testtgrass|gap_9|testtgrass|2012-08-26 00:00:00|2012-08-27 00:00:00|1.0|6.0
gap_9@testtgrass|gap_9|testtgrass|2012-08-27 00:00:00|2012-08-28 00:00:00|1.0|7.0
gap_9@testtgrass|gap_9|testtgrass|2012-08-28 00:00:00|2012-08-29 00:00:00|1.0|8.0
gap_10@testtgrass|gap_10|testtgrass|2012-08-30 00:00:00|2012-08-31 00:00:00|1.0|10.0
gap_10@testtgrass|gap_10|testtgrass|2012-08-31 00:00:00|2012-09-01 00:00:00|1.0|11.0
gap_10@testtgrass|gap_10|testtgrass|2012-09-01 00:00:00|2012-09-02 00:00:00|1.0|12.0
gap_10@testtgrass|gap_10|testtgrass|2012-09-02 00:00:00|2012-09-03 00:00:00|1.0|13.0
Here it works if I give one day before the actual valid temporal image in the where condition. So if I give “start_time > ‘2012-08-19 00:00:00’”, the first gap will also get filled*.* But It would be great if we can query on the missing dates/time.
All suggestions welcome.
Thanks in advance
Regards
Sajid
http://gis.cri.fmach.it/pareeth/
Fondazione Edmund Mach
Research and Innovation Centre
GIS and Remote Sensing Unit/Limnology and River ecology
Via Mach 1, 38010 San Michele all’Adige (TN) - Italy
Phone +39 461 615 669
spareeth@gmail.com
sajid.pareeth@fmach.it
skype: spareeth
Hi Sajid,
until today, t.rast.gapfill did not support interpolation by granularity.
However, please try revision r64651 in grass7.1 trunk. This feature
has now been implemented and should work as you would expect.
Of course, heavily testing is still needed.
I am still investigating the case when no gaps are found using the
where condition.
Best regards
Soeren
2015-02-05 19:23 GMT+01:00 sajid pareeth <spareeth@gmail.com>:
Hi
I am trying to use the module "t.rast.gapfill" to fill the gaps in my
##Q1:
r.mapcalc expr="map1 = 1" --o
r.mapcalc expr="map2 = 3" --o
r.mapcalc expr="map3 = 5" --o
r.mapcalc expr="map4 = 7" --o
r.mapcalc expr="map5 = 9" --o
t.create type=strds temporaltype=absolute output=mapT1 title="test for all
the gaps filled together" description="test for all the gaps filled
together"
00:00:00|1.0|0.0
00:00:00|1.0|2.0
00:00:00|1.0|5.0
00:00:00|1.0|9.0
00:00:00|1.0|14.0
# Doing the gapfill:
00:00:00|1.0|0.0
00:00:00|1.0|1.0
00:00:00|1.0|2.0
00:00:00|1.0|3.0
00:00:00|1.0|4.0
00:00:00|1.0|5.0
00:00:00|1.0|6.0
00:00:00|1.0|7.0
00:00:00|1.0|8.0
00:00:00|1.0|9.0
00:00:00|1.0|10.0
00:00:00|1.0|11.0
00:00:00|1.0|12.0
00:00:00|1.0|13.0
00:00:00|1.0|14.0
images?
###2.
When I try to do gap fill with the "where" condition, I am getting no
t.rast.gapfill input=mapT1 where="start_time = '2012-08-21 00:00:00'"
base=gap
No gaps found
OR when I try;
t.rast.gapfill input=mapT1 where="start_time > '2012-08-20 00:00:00'"
base=gap
00:00:00|1.0|0.0
00:00:00|1.0|2.0
00:00:00|1.0|3.0
00:00:00|1.0|4.0
00:00:00|1.0|5.0
00:00:00|1.0|6.0
00:00:00|1.0|7.0
00:00:00|1.0|8.0
00:00:00|1.0|9.0
00:00:00|1.0|10.0
00:00:00|1.0|11.0
00:00:00|1.0|12.0
00:00:00|1.0|13.0
00:00:00|1.0|14.0
the where condition. So if I give "start_time > '2012-08-19 00:00:00'", the
first gap will also get filled. But It would be great if we can query on the
missing dates/time.
Thanks in advance
Regards
Sajid
Via Mach 1, 38010 San Michele all'Adige (TN) - Italy
spareeth@gmail.com
skype: spareeth
grass-user mailing list
grass-user@lists.osgeo.org
Hi Soeren
Thank you for the great addition; I tested with the test data and it works as expected.
I will let you know if I find something unusual when I apply the command on my data.
On the related topic, I have another query;
When I do t.rast.list with “method=gran” the “where” condition is not working. With all the other methods it works.
Based on the same demo data;
t.rast.list input=mapT3 column=name,start_time method=gran where=“start_time > ‘2012-08-30 00:00:00’”
id>name>mapset>start_time|end_time|interval_length|distance_from_begin
map1@ecmwf|map1|ecmwf|2012-08-20 00:00:00|2012-08-21 00:00:00|1.0|0.0
gap_10_1@ecmwf|gap_10_1|ecmwf|2012-08-21 00:00:00|2012-08-22 00:00:00|1.0|1.0
map2@ecmwf|map2|ecmwf|2012-08-22 00:00:00|2012-08-23 00:00:00|1.0|2.0
gap_11_1@ecmwf|gap_11_1|ecmwf|2012-08-23 00:00:00|2012-08-24 00:00:00|1.0|3.0
gap_11_2@ecmwf|gap_11_2|ecmwf|2012-08-24 00:00:00|2012-08-25 00:00:00|1.0|4.0
map3@ecmwf|map3|ecmwf|2012-08-25 00:00:00|2012-08-26 00:00:00|1.0|5.0
gap_12_1@ecmwf|gap_12_1|ecmwf|2012-08-26 00:00:00|2012-08-27 00:00:00|1.0|6.0
gap_12_2@ecmwf|gap_12_2|ecmwf|2012-08-27 00:00:00|2012-08-28 00:00:00|1.0|7.0
gap_12_3@ecmwf|gap_12_3|ecmwf|2012-08-28 00:00:00|2012-08-29 00:00:00|1.0|8.0
map4@ecmwf|map4|ecmwf|2012-08-29 00:00:00|2012-08-30 00:00:00|1.0|9.0
gap_13_1@ecmwf|gap_13_1|ecmwf|2012-08-30 00:00:00|2012-08-31 00:00:00|1.0|10.0
gap_13_2@ecmwf|gap_13_2|ecmwf|2012-08-31 00:00:00|2012-09-01 00:00:00|1.0|11.0
gap_13_3@ecmwf|gap_13_3|ecmwf|2012-09-01 00:00:00|2012-09-02 00:00:00|1.0|12.0
gap_13_4@ecmwf|gap_13_4|ecmwf|2012-09-02 00:00:00|2012-09-03 00:00:00|1.0|13.0
map5@ecmwf|map5|ecmwf|2012-09-03 00:00:00|2012-09-04 00:00:00|1.0|14.0
But when I change the method to any other type, say delta, it works
t.rast.list input=mapT3 column=name,start_time method=delta where=“start_time > ‘2012-08-30 00:00:00’”
gap_13_2@ecmwf|gap_13_2|ecmwf|2012-08-31 00:00:00|2012-09-01 00:00:00|1.0|0.0
gap_13_3@ecmwf|gap_13_3|ecmwf|2012-09-01 00:00:00|2012-09-02 00:00:00|1.0|1.0
gap_13_4@ecmwf|gap_13_4|ecmwf|2012-09-02 00:00:00|2012-09-03 00:00:00|1.0|2.0
map5@ecmwf|map5|ecmwf|2012-09-03 00:00:00|2012-09-04 00:00:00|1.0|3.0
Regards
Sajid
On Mon, Feb 16, 2015 at 3:51 PM, Sören Gebbert <soerengebbert@googlemail.com> wrote:
Hi Sajid,
where condition.
Best regards
Soeren
Hi
##Q1:
together”
00:00:00|1.0|0.0
00:00:00|1.0|2.0
00:00:00|1.0|5.0
00:00:00|1.0|9.0
00:00:00|1.0|14.0
Doing the gapfill:
00:00:00|1.0|0.0
00:00:00|1.0|1.0
00:00:00|1.0|2.0
00:00:00|1.0|3.0
00:00:00|1.0|4.0
00:00:00|1.0|5.0
00:00:00|1.0|6.0
00:00:00|1.0|7.0
00:00:00|1.0|8.0
00:00:00|1.0|9.0
00:00:00|1.0|10.0
00:00:00|1.0|11.0
00:00:00|1.0|12.0
00:00:00|1.0|13.0
00:00:00|1.0|14.0
images?
###2.
base=gap
No gaps found
OR when I try;
base=gap
00:00:00|1.0|0.0
00:00:00|1.0|2.0
00:00:00|1.0|3.0
00:00:00|1.0|4.0
00:00:00|1.0|5.0
00:00:00|1.0|6.0
00:00:00|1.0|7.0
00:00:00|1.0|8.0
00:00:00|1.0|9.0
00:00:00|1.0|10.0
00:00:00|1.0|11.0
00:00:00|1.0|12.0
00:00:00|1.0|13.0
00:00:00|1.0|14.0
missing dates/time.
Thanks in advance
Regards
Sajid
