[GRASS-user] Questions related with wxpython modules in Windows
Greetings All
I’m reading http://grass.osgeo.org/wiki/WxPython-based_GUI_for_GRASS website and I got a few questions about digitizers implementation in GRASS:
1- i.ortho.photo ==> in my wxpython this option is in grey and I cannot run it. Is not working in WinGRASS?
2- Is it expected to have a vector digitizer and raster digitizer modules working in 6.4 version for Windows?
Thanks
Bye,
Franz
2009/12/2 Franz Schiller <franzschiller1975@gmail.com>:
Yes, it requires X monitors. The module need to be complete rewritten
and integrated into wxGUI (no developer yet, long term period).
There is no raster digitizer in wxGUI. Vector digitizer can basically
work on Windows. Needs some investigation.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
2009/12/3 Franz Schiller <franzschiller1975@gmail.com>:
Ok, now it makes sense. i.ortho.photo just like i.class requires X monitors
so they are not available to windows. Right?
right.
About vector digitalization. In the menu it doesn't appear in wxpython menu
but if a write v.digitizer it opens a wxpython menu and when I run it runs
in tcltk. is this what is expected to happen?
I guess you mean v.digit - it's TCL/TK-based digitizer. wxGUI
digitizer is intergrated into the GUI, you can start it from map
display toolbar ('digitize') or from map layer popup menu ('start
editing').
Martin
Are these options "blocked" only in Windows or also in Linux?
Thanks for your help
No, wxGUI vector digitizer should work on Linux and Mac OS X.
Martin
PS: Please keep discussion on ML.
Greetings all
After a few emails with Martin let me summarize this (and now for all grass user community):
  • v.digit is working in TCLtk in windows
  • digitizer is working in Wxpython in Linux and OS Mac
  • digitizer is not working in wxpython in windows (the option to start editing is not avaiable) and when I select digitizer (in map window combobox) a error window appeared saying "Unable to start vector digitizer. The vdigit python extension was not found or loaded properly, Swithcing back to 2D display Module. Details: No module named grass6_wxvdigit.
But when I write v.digit in wxpyhon (in Windows) I get the tcltk vector digitizer.
Just confirm me that this is an adequate sum of the digitizer situation for windows users
Thanks Martin for your help
Franz
user community):
- v.digit is working in TCLtk in windows
- digitizer is working in Wxpython in Linux and OS Mac
- digitizer is not working in wxpython in windows (the option to start
digitizer.
windows users
it's right.
Martin
Hello Martin and everyone
I’ve just installed GRASS 6.4 on a LINUX machine, because I wanted to test Vector digitzer from in wxpython, and I get this warning at console:
WARNING: Vector digitizer is not available (No module named grass6_wxvdigit).
According to your previous message it should be working but neither digitizer option (in map display) and “Start editing” button (from layer manager) on selected vector map is working. Although, v.digit, from tcltk is still working
Question: Am I the only one that can operate Vector_Digitizing_Tool in wxpython?
Thanks
Best regards
Franz
On Thu, Dec 3, 2009 at 10:31 AM, Martin Landa <landa.martin@gmail.com> wrote:
Are these options “blocked” only in Windows or also in Linux?
Martin
