[GRASS-user] quick way to create a mask and region after zooming in?
Hi Vishal
in grass7 you have an option in the gui, in the map display window under
"different zoom options", to set computational region from current display.
So, you zoom to the desired extent of your area and set the region with
that option. You can then save it with g.region -s region=my_region (in the
PERMANENT mapset) and you don't need to apply any mask (unless you have to
mask certain values), cuz all processing will be done in the computational
region.
HTH :slight_smile:
Best,
Vero
hi all,
i want to zoom into a region of interest and have that be the extent of a
mask and a named region.(no single map layer quite covers the region of
interest)
isn't there a a command or flag with g.region or r.mask to do this? if not
i'm looking at having to digitize a polygon after zooming in, or manually
jotting down the corners of the display window and piping it to g.region.
thanks,
Vishal
Vishal K. Mehta, PhD
Scientist
Stockholm Environment Institute - US
133 D St Suite F
Davis CA 95616
www.sei-us.org
On Thu, Jul 3, 2014 at 8:01 AM, Veronica Andreo <veroandreo@gmail.com>
wrote:
Hi Vishal
that option.
You can then save it with g.region -s region=my_region (in the PERMANENT
mapset) and you don't need to apply any mask (unless you have to mask
region.
Note that you "can save it", you don't have to. "Setting" the region is
enough.
Note also that
-d Set from default region
-s Save as default region
while
save Save current region settings in named region file
region Set current region from named region
See g.region --help for details.
The Map Display in GUI (the various zoom options button) lets you to save
named region and set named region. It also allows you to zoom to these
regions (without setting the region).
There is a lot of options but at the begging it is enough to know "set
computational region interactively", "set computation region extent from
display extent" (button in Map Display) and "set region from raster map"
(right click in Layer Manager).
Vaclav
HTH :slight_smile:
Best,
Vero
hi all,
interest)
thanks,
Vishal
Scientist
133 D St Suite F
Davis CA 95616
www.sei-us.org
grass-user mailing list
grass-user@lists.osgeo.org
