Hello everyone,
I’m using the 3D-Forest-Fragementation Modul developed by Vaclav and have produced a workflow for the calculation. It is working well and I’m getting plausible results. While applying this workflow for my whole study region (35 plots/regions) it only works for about 50 % of the plots. The others fail at the step where I use r3.count.categories. I can’t see the link respectively the difference for this error. That’s why am asking for a hint:
I’m running Grass 7.8.2 (64 bit), Python 3.7.0, wxPython 4.0.7 on Windows 10
The problem occurs while running this command:
"r3.count.categories input=ff_mean_131_2 output=ff_mean_131_2_count slices=ff_mean_131_2_slice --overwrite"
With this error:
Raster map 22 Filename: ff_mean_131_2_slice_00022
Raster map 23 Filename: ff_mean_131_2_slice_00023
WARNING: ZSTD compression error -14: Unsupported frame parameter
ERROR: Error uncompressing raster data for row 43 of <ff_mean_131_2_slice_00010>
ERROR: An error occurred while running r.mapcalc with expression: ff_mean_131_2_count_0 = int(ff_mean_131_2_slice_00001 == 0) + […]"
For each failing plot the error occurs in this step. The slices seem to be generated correctly. I couldn’t see differences while displaying them or comparing the raster metadata.
In the different plot its always another slice (2D Raster) and another row where the uncompressing fails. I tried to reduce the plot-size and found out, that the error occurs always in the same row of a plot. If this row is excluded, it works fine.
That’s why I think it has nothing to do with missing space on disk, or not enough calculating capacity.
Has someone an idea what’s the problem? Thanks very much!
Greetings,
Olivier
Hi Olivier,
<Olivier.C.Canon@umwelt.uni-giessen.de> schrieb am Do., 16. Juli 2020, 15:38:
Hello everyone,
“r3.count.categories input=ff_mean_131_2 output=ff_mean_131_2_count
slices=ff_mean_131_2_slice --overwrite”
With this error:
Did you copy by chance the data from a different machine?
This error comes to mind:
https://lists.osgeo.org/pipermail/grass-user/2019-March/080180.html
Best
markusN
for row 43 of
Greetings,
Olivier
grass-user mailing list
grass-user@lists.osgeo.org
Hi Markus,
no, I’m working on the same machine all the time. As external input data I use point cloud data in las-format that were generated with drone deploy. I had some trouble with the point clouds in the beginning, but I managed to convert them and load them in grass. The processing of the point clouds (rasterization, calculation of fragmentation index) works well now. I also use the DTM from Dronedeploy as base raster, but that shouldn’t have an effect on the rasterized point cloud.
Zitat von Markus Neteler <neteler@osgeo.org>:
Hi Olivier,
15:38:
Hello everyone,
10
With this error:
Best
markusN
for row 43 of
Greetings,
Olivier
Hello,
I solved my problem and wanted share the solution:
Updating Grass and ZSTD helped to remove the error code.
However, the resulting maps were empty. The problem seems to be the base raster I used in the steps before. I don’t know why 50 % of DTM caused the problems, as I couldn’t find any error in this data. But exporting them as Geopackage and reimporting in Grass solved the problem.
Hi Olivier,
15:38:
Hello everyone,
10
With this error:
Best
markusN
for row 43 of
Greetings,
Olivier
Hi Olivier,
On Tue, Jul 21, 2020 at 8:39 PM <Olivier.C.Canon@umwelt.uni-giessen.de> wrote:
Hello,
Great news!
problem.
Apparently still something depending on the version of ZSTD in
combination with the operating system.
In case you come across a reproducible error, please let us know.
