[GRASS-user] R and GRASS (readVECT6 problem)
I am using the latest GRASS windows binary (WinGRASS-6.4.0SVN-r39626-1-Setup.exe) on W2K. My R version is 2.9.2.
After starting R from within GRASS, loading the library(spgrass6) it is not possible to use the readVECT6 command (with the South-Dakota dataset) in R:
> map <- readVECT6("bugsites")
Error in vInfo(vname) : Vector information not found
readRAST6() and gmeta6() both works fine.
Does anybody have the same error and can give a hint, why this error occures?
Martin
The last time this was seen, it was a locale problem. I heard today something
from that questioner, who asked on the more relevant statsgrass list. Try
setting your locale to an English one. I'll try to release the package with
a patch, although the original questioner did not report success (but that
could be because he was unable to install a source package).
Roger
Martin Maier-2 wrote:
dataset) in R:
occures?
Martin
grass-user mailing list
grass-user@lists.osgeo.org
Roger Bivand
Economic Geography Section
Department of Economics
Norwegian School of Economics and Business Administration
Helleveien 30
N-5045 Bergen, Norway
View this message in context: http://n2.nabble.com/R-and-GRASS-readVECT6-problem-tp3913174p3915521.html
With R version 7.10.0 everything works fine with readVECT6() on my machine.
Thanks!
Martin
Roger Bivand schrieb am 29.10.2009 22:07:
Roger
dataset) in R:
occures?
