[GRASS-user] R and RStudio in winGRASS - testing welcome
Forgot to post also in the list for future reference :slight_smile:
Hi again,
I tested just now, and it works perfectly :slight_smile:
I used latest wingrass standalone installer (r66823) in windows 7, is it already also in OSGeo4W-winGRASS?
This is awesome… hope everything could keep moving in the direction of making GRASS in Windows as great as it is in Linux :slight_smile:
Best and thanks!!!
Vero
2015-11-14 15:22 GMT-03:00 Veronica Andreo <veroandreo@gmail.com>:
Hi Helmut!
First of all, sorry for very late response… I was preparing a GRASS course and this week I was teaching it… :slight_smile:
It went fine (especially for first time being a teacher), but as I’m a linux GRASS user, I was a bit in a lost with windows issues… that’s why I’ve been asking in the list… I remember seeing an email of yours suggesting this “clink” for windows command line to have bash-style command line editing… what happened with that?? any feedback?
I’ll try to test during these days what you mentioned, and let you know (will experiment on my mum’s pc :D)
Thanks for email and all your help!
Best,
Vero
On Sun, Nov 15, 2015 at 5:30 PM, Veronica Andreo <veroandreo@gmail.com> wrote:
Hi again,
This is awesome... hope everything could keep moving in the direction of
Best and thanks!!!
Vero
Great!
In r66837 I have backported the change to 7.0.svn (for 7.0.2).
The next OSGeo4W winGRASS 7.0 snapshot will contain the change, please
(also others) test.
Just run the OSGeo4W installer again and it will pick the updates.
Then we may release 7.0.2.
Markus Neteler wrote
On Sun, Nov 15, 2015 at 5:30 PM, Veronica Andreo &lt;
veroandreo@
Hi again,
Best and thanks!!!
Vero
Great!
(also others) test.
grass-user mailing list
grass-user@.osgeo
at the moment the R and RStudio integration is only implemented in the
standalone winGRASS installers; not yet in OSGeo4W, see
https://trac.osgeo.org/osgeo4w/ticket/413
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/R-and-RStudio-in-winGRASS-testing-welcome-tp5235108p5236435.html
From the ticket I don't understand what needs to be done and by whom...
best,
On Sun, Nov 15, 2015 at 5:34 PM, Helmut Kudrnovsky &lt;
hellik@
best,
there are some nice files in our source (marked as external [1]) which ease
the R-integration in windows command line/winGRASS command line in a quite
easy way [2].
at the moment, these files aren't integrated in the OSGeo4W build of GRASS
as these external files aren't part of any make/install process.
two possibilities:
(A) add these files to OSGeo4W itself and do some magic like [2]
(B) add these files to OSGeo4W-winGRASS and do some magic like [2]
regarding implementation:
(A) would need approval by OSGeo4W
(B) would need some effort on the GRASS side
another thing is adding RStudio to path [3]; that may be quite easy in
OSGeo4W.
[1]
https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/external/rbatch
[2] https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/env.bat#L29
[3] https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/env.bat#L24
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/R-and-RStudio-in-winGRASS-testing-welcome-tp5235108p5236498.html
hellik@
best,
ease the R-integration in windows command line/winGRASS command line in a
quite easy way [2].
two possibilities:
OSGeo4W.
[1]
regarding RStudio to path in OSGeo4W-winGRASS:
I've added the same logic as in the standalone winGRASS installer by [1].
testing welcome.
if this works, open issue is then OSGeo4W-winGRASS-R-coupling as it works
nicely in the standalone-winGRASS installer.
[1] https://lists.osgeo.org/pipermail/grass-commit/2015-November/037740.html
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/R-and-RStudio-in-winGRASS-testing-welcome-tp5235108p5236499.html
I’ve updated and calling rstudio from terminal works also for GRASS 7.1 from OSGeo4W :slight_smile:
Nice!
Best,
Vero
2015-11-15 21:09 GMT-03:00 Helmut Kudrnovsky <hellik@web.de>:
hellik@
From the ticket I don’t understand what needs to be done and by whom…
best,
quite easy way [2].
at the moment, these files aren’t integrated in the OSGeo4W build of GRASS
as these external files aren’t part of any make/install process.
two possibilities:
OSGeo4W.
[1]
I’ve added the same logic as in the standalone winGRASS installer by [1].
testing welcome.
best regards
Helmut
grass-user@lists.osgeo.org
On Mon, Nov 16, 2015 at 1:10 PM, Veronica Andreo <veroandreo@gmail.com> wrote:
I've updated and calling rstudio from terminal works also for GRASS 7.1 from
Nice!
Thanks for testing, Vero!
So I'll backport r66840, that seems to be sufficient, Helli?
Nice!
Done in r66850.
