[GRASS-user] r.average with winGRASS
Thanks a lot, Paul, for your explanation.
At the moment I can’t apply your patch (I lack a cross-compiling environment to Windows), so I’ll wait for the modules to be fixed. For the time being, I think I’ll be able to bypass this problem.
Eduardo
On Fri, 3 Nov 2006, Eduardo Hdo. Izcara wrote:
I’m trying to run the command r.average with the Windows GRASS 6.3.x development version, nicely provided by Huidae Cho. I always obtain de message:
“ERROR running r.stats command”
No matter what the raster base and cover input are, the result is always the same.
Does somebody know about some issue with the Windows versions of those commands? Of course, the Linux version works perfectly with the same arguments…
Yes, it was an issue with the module calling other modules using
G_system(). I expect there will be lots of issues like that with native
Windows GRASS, but they can be fixed. The patch included below fixes it
for now, but I don't want to apply it to CVS because (a) it isn't totally
correct, and it should convert the tempfile pathnames to Windows directory
separators - also it may depend on the shell being used - can you redirect
standard input from a file with cmd.exe? Perhaps you can and this is OK...
and (b) I'd rather find out why G_system() doesn't work than have to
change it to system() everywhere. But we'll get it working eventually.
Paul
Index: main.c
RCS file: /home/grass/grassrepository/grass6/raster/r.average/main.c,v
retrieving revision 2.8
diff -u -r2.8 main.c
--- main.c 24 Sep 2006 17:44:00 -0000 2.8
+++ main.c 3 Nov 2006 10:20:05 -0000
@@ -89,9 +89,9 @@
     tempfile1 = G_tempfile();
     tempfile2 = G_tempfile();
     G_message("%s:",STATS);
- sprintf (command, "%s -anC input='%s,%s' fs=space > %s",
+ sprintf (command, "%s -anC input=\"%s,%s\" fs=space > \"%s\"",
        STATS, basemap->answer, covermap->answer, tempfile1);
- if ((stat = G_system(command)))
+ if ((stat = system(command)))
        unlink(tempfile1);
        G_fatal_error(_("%s: ERROR running %s command"), G_program_name(),
STATS
@@ -149,9 +149,9 @@
     fclose (fd1);
     fclose (fd2);
     G_message("%s:",RECODE);
- sprintf (command, "%s input='%s' output='%s' < %s",
+ sprintf (command, "%s input=%s output=%s < \"%s\"",
        RECODE, basemap->answer, outputmap->answer, tempfile2);
- stat = G_system(command);
+ stat = system(command);
     unlink (tempfile1);
     unlink (tempfile2);
