[GRASS-user] r.basin: Completes on Some Basins, Fails on Others
   Running r.basin using r.to.vect basin boundaries and r.to.vect
r.stream.extract weighted streams (but same issue using unweighted streams).
So far, of 7 sub-basins on which I've run the module only 4 complete
successfully. The other three go through the entire process then fail with
the error message that the outlet needs to be on a stream channel created by
r.stream.extract.
   I use the same protocol on each sub-basin: zoom in very close to where the
sub-basin boundary and stream channel cross, then note the x, y coordinates
from the status line on the display window frame.
   What might account for this same process, using the same r.stream.extract
map, to work on some sub-basins and fail on others?
Rich
by
r.stream.extract.
AFAIK from my r.basin-tests the outlet-point has to be exactly on stream
channel created by r.stream.extract
the
maybe following ML-disscussion could be helpfull to find the exact crossing
of stream and boundary:
[GRASS-user] intersection between two lines vector to obtain points:
http://lists.osgeo.org/pipermail/grass-user/2012-March/064062.html
http://lists.osgeo.org/pipermail/grass-user/2012-March/064063.html
and then v.to.db to upload exact x,y-coordinates in the attribute table
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-basin-Completes-on-Some-Basins-Fails-on-Others-tp4979599p4979607.html
crossing of stream and boundary:
   What v.clean tool should be used in this case?
Thanks, Helmut,
Rich
v.clean tool=break
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-basin-Completes-on-Some-Basins-Fails-on-Others-tp4979599p4979644.html
Helmut,
would you mind to write your suggestion in the r.basin wiki page[1]?
Thanks!
ciao madi
[1] http://grass.osgeo.org/wiki/R.basin
On Thu, Jun 7, 2012 at 8:24 AM, Helmut Kudrnovsky <hellik@web.de> wrote:
v.clean tool=break
best regards
Helmut
Dr. Margherita Di Leo
I get a similar issue some time ago (but with a vector input) and wrote a little script to work only with raster (no need to transform back to vector)
it’s using r.distance (http://grass.osgeo.org/grass64/manuals/html64_user/r.distance.html), wich “Locates the closest points between objects in two raster maps” and output an ascii line with the intersection point …
you just need to input your 2 raster with basin boundaries and streams, and it will do the job for all your objects at once :wink:
Sylvain
2012/6/6 Rich Shepard <rshepard@appl-ecosys.com>
So far, of 7 sub-basins on which I’ve run the module only 4 complete
r.stream.extract.
Rich
Thanks!
sure, it's taken from http://www.surfaces.co.il/?p=241
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-basin-Completes-on-Some-Basins-Fails-on-Others-tp4979599p4979663.html
done, please expand if needed
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-basin-Completes-on-Some-Basins-Fails-on-Others-tp4979599p4979677.html
v.clean tool=break
Helmut,
   Good. That's what I chose.
Rich
v.clean tool=break
Helmut,
now there is a new and related wiki-entry (section Preparation, last
paragraph)
http://grass.osgeo.org/wiki/R.basin#Preparation
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-basin-Completes-on-Some-Basins-Fails-on-Others-tp4979599p4979751.html
Hi Helmut:
I think you had a typo between the names crosspoints and crosspointscat in one line. I took the liberty of fixing, and changing a few other layer names for readability. If you could have a look to be sure it still reads correctly?
The next addition might be how feed these crosspoints X and Y straight into the easting and northing of r.basins…
BTW, thanks for mentioning my blog earlier in the thread :slight_smile:
Micha
Hi Micha,
you mean something like (untested):
#!/usr/bin/env python
fin = open(“crosspoints”,“r”)
fout = open(“commands”,“w”)
linesout = (line.rstrip().split() for line in fin)
cmd = ‘r.basin map=dem prefix=bas%s easting=%s northing=%s threshold=10000\n’
fout.writelines(cmd % (n, easting, northing) for n,(easting,northing) in enumerate(linesout))
ciao madi
Hi, I run the example of r.basin and I get this message at the end:
File “/home/admin-lsc/Grass/Modulos/r.basin.py”, line 427, in
sys.exit(main())
File “/home/admin-lsc/Grass/Modulos/r.basin.py”, line 235, in main
mainchannel = float(dict_mainchannel[‘Length’]) / 1000
KeyError: ‘Length’
by
r.stream.extract.
the
best regards
Helmut
grass-user mailing list
grass-user@lists.osgeo.org
David Montoya González
Ing. Forestal, Universidad Nacional de Colombia
Laboratorio de Sistemas Complejos, UNAL Medellin
David,
sys.exit(main())
KeyError: ‘Length’
Which example do you refer to (exact commands and dataset)? and when did you download r.basin? On which OS and grass version?
madi
   Micha wrote an excellent description that answered a number of questions
for me. Now I'm ready to try r.basin again and want to check the validity of
my understanding of how I got where I now am and where it's going with
r.basin.
   The input to r.stream.extract came from r.watershed with this command:
r.watershed elev=dem_10m acc=facc drain=fdir basin=catch stream=str thresh=50000
and was followed by r.stream.extract:
r.stream.extract elev=dem_10m acc=facc thresh=1000 stream_rast=rstream stream_vect=vstream
   To find the sub-basin outlets,
v.patch in=catchments,vstream out=basin_stream
and
v.clean in=basin_vstream out=basin_vstream_clean tool=break error=cross_points
   Prior to running v.out.ascii to save the cross_points in a text file I
carefully manually deleted extraneious tiny sub-basins and cross_points at
the confluences of stream channels. This reveals that many cross_points are
not on sub-basin boundaries generated by r.watershed.
   In Micha's blog article the cross_points.txt file is used as input to
r.water.outlet which generates the appropriate catchments. I assume this is
also true for r.basin; i.e., it will generate its own basins and sub-basins
based on the outlet points in the cross_points.txt file. Is this assumption
correct?
   My thanks to Markus(M), Madi, Helmut, and Micha.
Rich
one line. I took the liberty of >fixing, and changing a few other layer
correctly?
thanks for clarification
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-basin-Completes-on-Some-Basins-Fails-on-Others-tp4979599p4979916.html
On Fri, Jun 8, 2012 at 1:44 AM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
In Micha’s blog article the cross_points.txt file is used as input to
correct?
Correct. I’ve updated the wiki page http://grass.osgeo.org/wiki/R.basin#Preparation_for_multiple_basins.27_analysis
Rich, if you’ll test this method, I would appreciate your feedback. Feel free to improve the wiki page (and to put it into real english :stuck_out_tongue: )
ciao madi
I did the example suggested on the wiki page, the same maps and the same commands. I’m using Grass 6.4.2svn under Ubuntu, I’m going to update the addons because I downloaded them one year ago
On Thu, Jun 7, 2012 at 11:15 AM, Margherita Di Leo <diregola@gmail.com> wrote:
David,
sys.exit(main())
KeyError: ‘Length’
madi
David,
yes this could be the problem, something has been updated in the code. Please update r.basin and all the add-ons it is based on, and report any problem. Thanks,
madi
correct?
Hi Madi:
Regarding the threshold value in your auxilliary parsing.py script, do you think it might be better to calcuclate a suggested value from the size of the original DEM, rather than just put in some random 10,000 or so.
Obviously the user has to understand, and change the threshold to suit his needs, but if the script is going to contain some value, maybe it should be something “reasonable”. I thought, for example to choose a suggested thresh size of num_cells/100. i.e.:
N=r.univar -g | grep "^n=" | cut -d "=" -f 2
THRESH=$(( $N / 100))
Does that sound reasonable? Since the python auxilliary script runs independently of GRASS, I’m not sure how how this would all merge together. But it’s worth thinking about.
Micha
