On Mon, Nov 12, 2012 at 7:01 PM, kapo coulibaly <kmcoulib@gmail.com> wrote:
I'm trying to install r.basin addon and I'm getting the following error:
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.2 sh
/usr/local/grass-6.4.2/tools/g.html2man
/root//test/scratch/.tmp/fmtslack64/26418.0/dist.x86_64-slackware-linux-gnu/docs/html/r.basin.py.html
/root//test/scratch/.tmp/fmtslack64/26418.0/dist.x86_64-slackware-linux-gnu/man/man1/r.basin.py.1
1
/usr/local/grass-6.4.2/tools/g.html2man:
/usr/local/grass-6.4.2/tools/g.html2man: is a directory
This should not be a directory. Could you please check what's inside?
inside /usr/local/grass-6.4.2/tools/g.html2man there is a file called g.html2man. I moved it outside and deleted the folder with the same name. After that r.basin installed without error. But when I try to run it get:
GRASS 6.4.2 (test):/usr/local/grass-6.4.2/tools > r.basin
/root/.grass6/addons/r.basin:572: Warning: ‘with’ will become a reserved keyword in Python 2.6
File “/root/.grass6/addons/r.basin”, line 572
with open(prefix+‘_parameters.csv’, ‘w’) as f:
SyntaxError: invalid syntax
I’m trying to install r.basin addon and I’m getting the following error:
1
This should not be a directory. Could you please check what’s inside?
This is due to Python 2.5.x, you need to upgrade to 2.6 in order to run r.basin.
Best regards,
m
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Forest Resources and Climate
I-21020 Ispra (VA) - Italy - TP 261
