I’m trying to run r.basin and I get the following error:
SECTION 1a (of 4): Initiating Memory.
SECTION 1b (of 4): Determining Offmap Flow.
SECTION 2: A * Search.
SECTION 3: Accumulating Surface Flow with SFD.
SECTION 4: Closing Maps.
Writing out only positive flow accumulation values.
Cells with a likely underestimate for flow accumulation can no longer be identified.
File “/home/user/grassdata/addons/r.basin”, line 663, in
sys.exit(main())
File “/home/user/grassdata/addons/r.basin”, line 151, in
main
overwrite = True)
File “/usr/lib/grass64/etc/python/grass/script/core.py”,
line 189, in run_command
ps = start_command(*args, **kwargs)
line 177, in start_command
return Popen(args, **popts)
line 56, in init
startupinfo, creationflags)
File “/usr/lib/python2.7/subprocess.py”, line 679, in init
errread, errwrite)
File “/usr/lib/python2.7/subprocess.py”, line 1249, in
_execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
(Wed Nov 28 19:36:58 2012) Command finished (20 sec)
I’m running the latest OSGeolive. But I got the exact same error on Slackware 13 and CentOS 6
File "/usr/lib/grass64/etc/python/grass/script/core.py",
File "/usr/lib/python2.7/subprocess.py", line 1249, in
These are python errors. do you have core.py and subprocess.py on your
systems? I'm still running python-2.6 on my Slackware hosts so it might be a
python-2.7 issue.
sys.exit(main())
main
overwrite = True)
line 56, in init
errread, errwrite)
_execute_child
What’s the exact command line that you are trying to run? Could you reproduce this error using NC dataset so that I can reproduce it as well?
madi
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Forest Resources and Climate
I-21020 Ispra (VA) - Italy - TP 261
The command using NC data on OSGEOLive 6.0 is attached. Thanks
(Tue Dec 4 14:13:38 2012)
r.basin -a map=elevation@PERMANENT prefix=ncbasin easting=641154 northing=222423
threshold : 10000.0
sys.exit(main())
main
overwrite = True)
line 56, in init
errread, errwrite)
_execute_child
(Tue Dec 4 14:14:03 2012) Command finished (24 sec)
On Thu, Nov 29, 2012 at 7:56 AM, Margherita Di Leo <diregola@gmail.com> wrote:
sys.exit(main())
main
overwrite = True)
line 56, in init
errread, errwrite)
_execute_child
madi
Margherita DI LEO
Thank you, I’ll check it later this evening and let you know. Just one further information: do you have r.stream.* modules (dependencies) already installed?
Best regards,
MaDi
Margherita DI LEO
You are right. installing the r.stream.* seems to have taken care of it.
thanks
On Tue, Dec 4, 2012 at 10:47 AM, Margherita Di Leo <diregola@gmail.com> wrote:
Best regards,
MaDi
Margherita DI LEO
Anyway I’ll add some controls to let it crash more graciously whenever a dependency is missing. Many thanks for your feedback.
thanks
Best regards,
MaDi
Margherita DI LEO
