[GRASS-user] r.basin: specifying closing point by geographic coordinates
   I have geographic coordinates for monitoring locations near the mouthes of
streams. Can I apply r.basin to each individual basin without using the
r.extract[ed] coordinates?
Rich
Hi Rich,
On Wed, Oct 24, 2012 at 4:56 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
As a general remark, you can always give a try with the coordinates that you already have, because it can happen that those exactly match the extracted river network, even if it is unlikely. By the way, i’ve never tested the script using lat/lon coordinates, but i suppose that you can get some of the parameters in a unit derived from degrees, which is not correct, so you need to use metric coordinates in order to get a suitable result. BTW, if you are willing to make a test on it and send (maybe privately) to me the results, I’ll appreciate. Thus I’ll update the documentation accordingly.
Thanks and regards.
madi
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Forest Resources and Climate
I-21020 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
madi,
   These are locations where water and benthic macroinvertebrates were
collected so if they're not exactly on the stream, they can easily be moved
to overlap the line without loss of ecological information.
By the way, i've never tested the script using lat/lon coordinates, but i
   The original measurements are in lat/lon but after importing to that
locations they were re-projected to the project location which uses the
State Plane Coordinate System projection; the units are in metres.
   I assume that if I provide one set of easting/northing coordinates the
script will run only once and define that specific drainage basin for me.
This assumption will be tested and results forwarded per your request below.
me the results, I'll appreciate. Thus I'll update the documentation
accordingly.
   Certainly.
Rich
suppose that you can get >some of the parameters in a unit derived from
once I've run the script in a lat/lon-wgs84-location, the results are odd.
yes
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-basin-specifying-closing-point-by-geographic-coordinates-tp5010864p5010896.html
