[GRASS-user] r.category value range
Hello!
I trying to set a label for a range of values in a raster.
I am using r.category (grass 7.0)
“r.category map=lwc_2014 separator=‘:’ rules=lwc.rules”
My lwc.rules looks like this:
0:30:0.9
31:90:0.7
91:252:0.5
so, r.category does not seem to read my range, but in stead gives me labels for value 31 (label=90:0.7) and value 91 (label=252:0.5)
Any clues to what I am doing wrong ? or is r.category not working as intended?
Martin
On 04/02/15 11:48, Martin Album Ytre-Eide wrote:
Hello!
"r.category map=lwc_2014 separator=':' rules=lwc.rules"
0:30:0.9
31:90:0.7
91:252:0.5
intended?
You should use r.recode, not r.category.
Moritz
On Wed, Feb 4, 2015 at 1:14 PM, Moritz Lennert
Hello!
0:30:0.9
31:90:0.7
91:252:0.5
intended?
According to the manual, r.category should work with these rules.
Markus M
Hello!
0:30:0.9
31:90:0.7
91:252:0.5
intended?
You're right. Sorry, I wrote to fast.
Actually the manual also says concerning the example: "The format is given as follows (when separator is set to colon)". So, AFAIU, you have to set the separator parameter to whatever separator you use in the rules.
Moritz
Hello!
0:30:0.9
31:90:0.7
91:252:0.5
intended?
Sorry, I really should take the time before I write. I can reproduce the issue actually:
g.copy raster=geology_30m,mygeol
r.category mygeol rules=- separator=':' <<EOF
217:270:1
405:862:2
910:948:3
EOF
r.category mygeol
217 270:1
262
270
405 862:2
583
720
766
862
910 948:3
921
945
946
948
So, yes, there seems to be a bug in r.category. Please file a ticket.
Moritz
Hello!
0:30:0.9
31:90:0.7
91:252:0.5
intended?
issue actually:
217:270:1
405:862:2
910:948:3
EOF
r.category mygeol
217 270:1
262
270
405 862:2
583
720
766
862
910 948:3
921
945
946
948
Looking at the code, I actually think that r.category works well in terms of setting the label for the range. At least the cats file reads:
# 948 categories
0.00 0.00 0.00 0.00
217:270:1
405:862:2
910:948:3
which looks correct to me.
However, it does not know how to display it in a decent manner. The same goes for d.legend. Or r.what. IIUC, modules that read cat values just don't seem to have been foreseen for this case.
So, for the OP, I would go back to my original answer to suggest using r.recode.
And maybe someone who understands the code better than me can clarify how GRASS is supposed to actually use such range labels ?
Moritz
Hey, thanks!
r.recode worked for me. As mentioned r.category clames it can do this, and in different cases - it might be more usefull to work with labels. I was trying to add labels and then do a "r.mapcalc expression="snow_type= @lwc_2014_05_15" " in order to use the labels as values. But r.recode did this in one go, so that was better. But if one was to use the labels in a label instead of the values - it would be good if the r.category worked as intended. I think I have done that before, so maybe label range (with r.category) works with d.legend? - did you try this Moritz?
Martin
________________________________________
Fra: grass-user-bounces@lists.osgeo.org [grass-user-bounces@lists.osgeo.org] p&#229; vegne av Moritz Lennert [mlennert@club.worldonline.be]
Sendt: 4. februar 2015 16:55
Til: Markus Metz
Kopi: grass-user@lists.osgeo.org
Emne: Re: [GRASS-user] r.category value range
Hello!
0:30:0.9
31:90:0.7
91:252:0.5
intended?
issue actually:
217:270:1
405:862:2
910:948:3
EOF
r.category mygeol
217 270:1
262
270
405 862:2
583
720
766
862
910 948:3
921
945
946
948
# 948 categories
0.00 0.00 0.00 0.00
217:270:1
405:862:2
910:948:3
r.recode.
Moritz
grass-user mailing list
On 05/02/15 11:12, Martin Album Ytre-Eide wrote:
Hey, thanks!
Yes, as I said: "However, it does not know how to display it in a decent manner. The same goes for d.legend. Or r.what. IIUC, modules that read cat values just don't seem to have been foreseen for this case."
I did not think about r.mapcalc. If you know that this worked with a specific version of GRASS, it would be interesting for us to know. That would allow us to retrace the changes that might have broken that feature.
Moritz
On Thu, Feb 5, 2015 at 11:40 AM, Moritz Lennert
Hey, thanks!
I think you would need to go back to GRASS 4.x to find out how these
rules were handled (back then by r.support). These rules, and the
format options, are pretty powerful, and it would be nice to have them
restored in GRASS 7.x.
Markus M
Moritz
0:30:0.9
31:90:0.7
91:252:0.5
intended?
i'm not sure to remember correctly but i think ranges should look like:
  0:30:0.9:0.9
31:90:0.7:0.7
91:252:0.5:0.5
maybe you can try if you get the expected result ...
