Dear all,
I just tried r.clump on a rastarized river with alternating patches of good
and bad habitat (values 1 and 2). However, due to its linear structure, many
cells of the same habitat patch are often only diagonally connected. So this
is a case where r.clump does not work (as stated in its manual).
So, as a suggestion, it’d be nice if also diagonal cells could be considered by r.clump (e.g. by setting a flag).
…or maybe someone of you has another idea to how to get unique values for each discrete patch (also diagonally connected cells of homogeneous habitat quality).
FYI r.clump has been tested on GRASS7.
best regards,
Johannes
Hi Johannes,
There is an add on module called r.clump4p available at at http://sil.uc.edu/downloads.html#software
It has an option to clump diagonal cells. It is also parallelized and completes much faster than r.clump.
Eric
On Jan 13, 2014 5:39 AM, “Johannes Radinger” <johannesradinger@gmail.com> wrote:
Dear all,
best regards,
Johannes
grass-user mailing list
grass-user@lists.osgeo.org
On Mon, Jan 13, 2014 at 12:39 PM, Johannes Radinger
Dear all,
So, as a suggestion, it'd be nice if also diagonal cells could be considered
Note that there is a more modern version here:
http://grasswiki.osgeo.org/wiki/AddOns/GRASS_6#r.clump2
http://grasswiki.osgeo.org/wiki/AddOns/GRASS7/raster#r.clump2
Thanks for the hint about r.clump2.
I just tried to apply it to my data. While this tool works with diagonally connected cells (in contrast to r.clump) it does not preserve the distinct category values of adjacent cells. Furthermore, as also mentioned in the manual: Linear elements are always clumped together, unless the e-flag is set (which basically ignores diagonally connected cells and thus is comparable to r.clump result). So as I’d like to have unique category values for the single (adjacent) patches this tool does not necessarily help me. However, good to know that there is such a tool available. For the moment, I’ll try an approach to buffer (r.grow) my raster lines before applying r.clump which could work.
best,
Johannes
Dear all,
Dear all,
I would recommend r.clump4p over r.clump2. r.clump4p is the fastest of
the three, even without parallelisation. Note that r.clump4p, like
r.clump, also clumps NULL cells, whereas only r.clump2 ignores NULL
cells.
Dear all,
Done in r59122. Diagonal cells are also considered with the new -d
flag. BTW, r.clump seems pretty fast to me, 200 million cells are
clumped in 10 seconds.
Markus M
...or maybe someone of you has another idea to how to get unique values for
quality).
best regards,
Johannes
