[GRASS-user] r.coin behaving differently
I am using r.coin for two raster maps
map1's range is
Range of data: min = 111 max = 140
map2' range
Range of data: min = 11111111 max = 175900000
I used to get this result with r.coin
| cat# | 111 | 112 | 120 | 130 | 140 |
  w cat 0 | w/o cat 0 |
|p 11111111 | 0.00 | 0.00 | 0.00 | 0.00 |
103.33 | 103.33 | 103.33 |
|h 12800000 | 8376.26 | 51848.35 | 395.22 | 5594.52 |
36.80 | 66251.15 | 66251.15 |
|i 12900000 | 0.00 | 10521.99 | 3791.04 | 636.42 |
162.64 | 15112.09 | 15112.09 |
|l 13300000 | 0.00 | 66.13 | 577.76 | 0.00 |
141.35 | 785.24 | 785.24 |
|p 15500000 | 2079.69 | 12411.01 | 440.71 | 1594.05 |
696.53 | 17221.99 | 17221.99 |
|r 20900000 | 51.59 | 3862.45 | 0.00 | 0.00 |
0.00 | 3914.03 | 3914.03 |
|o 21500000 | 112366.40 | 197525.87 | 0.00 | 17049.36 |
5081.42 | 332023.05 | 332023.05 |
Now I get a different cat# as row headers
|p 1 | 0.00 | 0.00 | 0.00 | 0.00 | 103.33 |
   103.33 | 103.33 |
|h 3 | 8376.26 | 62370.34 | 4186.26 | 6230.93 | 199.44 |
81363.24 | 81363.24 |
|i 4 | 0.00 | 66.13 | 577.76 | 0.00 | 141.35 |
   785.24 | 785.24 |
|l 7 | 2079.69 | 12411.01 | 440.71 | 1594.05 | 696.53 |
Any idea why? I'm running GRASS 6.4.0RC5 from kingchaos mac osx
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
Follow-up
On Wed, Apr 14, 2010 at 5:41 PM, maning sambale
<emmanuel.sambale@gmail.com> wrote:
map2' range
The range above is not are ordinal categories, they are simply polygon
codes of administrative regions.
cheers,
maning
Never mind, map2 was an Data Type: DCELL, simply convert them in to
CELL and its OK. Doh!
On Wed, Apr 14, 2010 at 5:44 PM, maning sambale
Follow-up
map2' range
cheers,
maning
cheers,
maning
