[GRASS-user] r.contour crashing
I've not been successful running r.contour on a raster which I made doing r.patch on a few SRTM tiles. After r.contour runs for a short while, disk activity goes up, and the progress indicator stops. Then after another minute, "killed" appears and the contour vector is not properly created. I tried with a smaller subsection of the raster, and it succeeded. Here's r.info on the raster that fails:
GRASS 6.2.3 (WGS84):~/geodata/ethiopia > r.info ethiopia_srtm
| Layer: ethiopia_srtm Date: Sat Feb 9 11:13:04 2008 |
| Mapset: PERMANENT Login of Creator: micha |
| DataBase: /home/micha/geodata/grass |
| Title: ( srtm_eth ) |
| timestamp: none |
| Type of Map: raster Number of Categories: 4517 |
| Data Type: CELL |
| Rows: 14400 |
| Columns: 18000 |
| Total Cells: 259200000 |
| Projection: Latitude-Longitude (zone 0) |
| N: 15N S: 3N Res: 0:00:03 |
| E: 46E W: 31E Res: 0:00:03 |
| Range of data: min = -197 max = 4517 |
| Data Source: |
| Data Description: |
| generated by r.patch |
| Comments: |
| r.patch input="srtm_eth3,44_12" output="srtm_eth" |
Is the region too large?
Micha
Micha Silver
Arava Development Co, Sapir, Israel
tel: +972(8)6592270
cell: +972(52)3665918
