[GRASS-user] r.contour fails to close a contour at the region's border
I have automatically generated raster data from which I create a contour using r.contour. Sometimes the “feature” to be contoured is not completely contained within the specified region. When this happens, r.contour generates an open contour - basically the beginning line segment point does not equal the ending line segment point.
Is there a way to get r.contour to close the contour at the region’s border?
If not, is there an easy way to close the contour?
Thanks
John Ciolek
Senior Atmospheric Scientist
AlphaTRAC, Inc.
P| 720-263-4271
C| 303-669-2752
www.AlphaTRAC.com
www.AlphaACT.com
using r.contour. Sometimes the "feature" to be contoured is not completely
Is there a way to get r.contour to close the contour at the region's border?
No. This is a feature of r.contour because it is impossible to tell
where a contour would continue if it hits the region's border.
Why do you want to close the contour?
If you want to convert the contour lines to areas, you might instead
modify the raster with r.mapcalc, e.g. for contours at every 100 unit
step
r.mapcalc "surface.classified = int(surface / 100) * 100"
but here a value of 99 would be converted to 0, thus as an alternative
r.mapcalc "surface.classified = int((surface + 50) / 100) * 100"
which would convert e.g. all values >= 50 and < 150 to 100.
After that the classified raster could be converted to vector areas
with r.to.vect type=area
HTH,
Markus M
I am trying to create areas from the contours, where the areas clip to the set region.
step
HTH,
Markus M
Wouldn't this create a very blocky contour?
The contouring is done in batch mode for a real-time modeling system. Right now I'm thinking it would be easiest to write a program to add one extra point to the vector if the first and last points do not match. Was hoping for an easier way.
John
step
HTH,
Markus M
The contours are as blocky as the current region settings, also with
r.contour. If you first classify the raster, then convert it to a
vector, you can use r.to.vect with the -s flag which creates smoothed
lines and boundaries. Then there is v.generalize for further
smoothing.
r.contour itself is slow, the r.mapcalc + r.to.vect approach could be faster.
Markus M
John
On Thu, Jan 9, 2014 at 9:57 AM, Markus Metz
step
HTH,
Markus M
r.contour.
Sorry, you are right, the contours generated by r.contour are not
blocky. You can convert the contour lines to areas with something like
DEM="elev_state_500m"
step=100
halfstep=`echo $step | awk '{printf "%.15g\n", $1 / 2.0}'`
g.region -p rast=$DEM
r.contour in=$DEM out=${DEM}_contour_3d step=$step
r.mapcalc "${DEM}_bin = if(isnull($DEM), null(), 1)"
# double the resolution
eval `g.region -g`
rows2=`echo $rows | awk '{printf "%d\n", $1 * 2}'`
cols2=`echo $cols | awk '{printf "%d\n", $1 * 2}'`
eval `g.region -g rows=$rows2 cols=$cols2`
# grow region by one cell
g.region -g n=n+$nsres s=s-$nsres e=e+$ewres w=w-$ewres
r.mapcalc "${DEM}_bin_inv = if(isnull(${DEM}_bin), 1, null())"
# shrink DEM by one cell
r.grow in=${DEM}_bin_inv out=${DEM}_bin_inv_grow old=1 new=2
metric=euclidean radius=1.5
r.mapcalc "${DEM}_bin2 = if(isnull(${DEM}_bin_inv_grow), 1, null())"
# area matching the r.contour contours
r.to.vect in=${DEM}_bin2 out=${DEM}_bin_area type=area
# patch countours with outer limit and clean up
v.extract in=${DEM}_bin_area out=${DEM}_bin_bounds type=boundary layer=-1
v.type in=${DEM}_bin_bounds out=${DEM}_bin_lines from_type=boundary to_type=line
# flatten contours for patching, needed to build areas
v.transform in=${DEM}_contour_3d out=${DEM}_contour_2d zscale=0
v.patch in=${DEM}_contour_2d,${DEM}_bin_lines out=${DEM}_patch
# clean up the patched vector
v.clean in=${DEM}_patch out=${DEM}_clean tool=snap,break thresh=1.0e-7
type=line -c
v.type in=${DEM}_clean out=${DEM}_bounds from_type=line to_type=boundary
v.clean in=${DEM}_bounds out=${DEM}_bounds_clean
tool=rmdangle,rmbridge type=boundary -c --v
v.centroids in=${DEM}_bounds_clean out=${DEM}_contour_areas
g.remove rast=${DEM}_bin,${DEM}_bin_inv,${DEM}_bin_inv_grow,${DEM}_bin2
g.remove vect=${DEM}_bin_area,${DEM}_bin_bounds,${DEM}_contour_2d,${DEM}_bin_lines
g.remove vect=${DEM}_patch,${DEM}_clean,${DEM}_bounds,${DEM}_bounds_clean
but I did not find a way to assign a reasonable elevation value to the
areas. The DEM used in this example is in the North Carolina sample
dataset.
The r.mapcalc + r.to.vect approach would be
step=100
r.mapcalc "${DEM}_contours = int(round(($DEM - $halfstep) / $step) * $step)"
r.to.vect in=${DEM}_contours out=${DEM}_contours_rtv type=area column=ele -s
Markus M
