Hi everyone.
I had generated some contours from a DEM with r.contour. In the resulting vector contour map, I get cat and level, where level is the elevation value. I must be confused with the level terminology, because I thought levels pertained to topological (2) or non-topological data (1). However, in r.contour output, “level attribute” corresponds with the contour elevation.
Regardless, I’m able to query the lines in GRASS monitor to get the cat and level (elevation) values for the contour lines, but in QGIS I’m unable to query or identify the features. In QGIS, I am able to label the lines on the “level” item though.
I refrained from cross posting to QGIS list, because it seems like something I’m not understanding in GRASS vector model.
Any ideas why the features are (repeatably) unidentifiable in QGIS, but are viewed and labeled without issue?
Mark
