[GRASS-user] r.cost vs. costallocation (arcgis)
Following my last two messages, to which I got no reply, I'll try to explain my situation a bit better...
For over 10 years, I used ESRI tools (AV Spatial Analyst, ArcInfo costdistance, ArcGIS costallocation)
to calculate accessibility and allocation surfaces, based on the cost surfaces methodology.
Recently, when starting a new project, I decided to demonstrate that I could do everything related to
spatial analysis and statistics using only opensource software (R, GRASS and QGIS). Everything is
actually going quite well, except for the problem I will again describe.
Cost distance and costallocation (arcinfo and arcgis) output two surfaces: an accessibility and an
allocation surface.
For verious reasons, I need both.
In GRASS, I had a look at r.cost, r.walk r.watershed and r.drain, trying to find a toll which could create
an allocation grid based on a cost surface. From what I could see, none of these tools will do.
I find it hard to believe that:
  1. No one have had this problem before using GRASS,
  2. there is no solution using GRASS.
If someone, anyone, could point me in "any" direction, it would be greatly appreciated. Even
something like: "dude, just give up, and go back to arcgis"...
If the solution involves programming a new tool, probably based on r.cost, is there some tutorials
online dealing with programming in GRASS?
Thank you.
António
allocation surface.
could you explain what an "allocation grid" is supposed to contain?
maybe it is a question of translating the jargon rather than
capability.
is the "accessibility surface" a 0/1 answer to "can I get there
from here, at any cost?
Hamish
