I am trying to run r.damflood but I am running into trouble. Unfortunately the documentation has no examples. I manage to make the script run but I can’t quite figure out what I need to use as input in order to get meaningful results.
I’ve tried to describe the steps I followed in this gist: https://gist.github.com/pmav99/d6162e1d82e9f23f769c
Does anyone have any idea what I am doing wrong?
Has anyone succesfully used this addon in the past? If you do, can you share an example?
with kind regards,
Panos
On Wed, Dec 2, 2015 at 7:20 AM, Panagiotis Mavrogiorgos <pmav99@gmail.com>
wrote:
can't quite figure out what I need to use as input in order to get
meaningful results.
I've tried to describe the steps I followed in this gist:
Nice! Some steps seems too complicated, I suggest using r.null for some of
the steps. I think the problem is the break raster. It should have 0
everywhere except for the part of dam which breaks, that part should have
the height of the dam break, for example tens of meters. r.damflood
computes internally the new DEM as DEM with the dam minus the break raster.
I hope it's clearer now.
Anna
share an example?
with kind regards,
Panos
grass-user mailing list
grass-user@lists.osgeo.org
On Wed, Dec 2, 2015 at 4:46 PM, Anna Petrášová <kratochanna@gmail.com>
wrote:
script run but I can't quite figure out what I need to use as input in
the steps.
I agree with you that it could be simplified, but I was trying to replicate
r.dam.
I think the problem is the break raster. It should have 0 everywhere
except for the part of dam which breaks, that part should have the height
of the dam break, for example tens of meters. r.damflood computes
internally the new DEM as DEM with the dam minus the break raster. I hope
it's clearer now.
I see, thank you
It does make sense now.
Question: Is it possible to make r.damflood take under consideration
downstream water (e.g. a lake or a river)?
On Fri, Dec 4, 2015 at 9:50 AM, Panagiotis Mavrogiorgos <pmav99@gmail.com>
> wrote:
of the steps.
replicate r.dam.
it's clearer now.
I see, thank you
I think so, but I haven't tested it. You would just incorporate it into the
lake raster.
