Hi all
I’m trying to run r.denoise from a python script but I’m getting some errors (below). Apparently this is about using pipe to redirect outputs (r.denoise is a bash script).
any ideas to work around this situation?
thanks
Carlos
grass.run_command(‘r.denoise’, input=elev, output=out_avg, iterations=n_iter, threshold=thrshld, epsg=4326, overwrite=ow)
File “”, line 1, in
File “/usr/local/Cellar/grass-73/7.3.svn_src_snapshot_latest/grass-7.3.svn/etc/python/grass/script/core.py”, line 408, in run_command
ps = start_command(*args, **kwargs)
File “/usr/local/Cellar/grass-73/7.3.svn_src_snapshot_latest/grass-7.3.svn/etc/python/grass/script/core.py”, line 377, in start_command
return Popen(args, **popts)
File “/usr/local/Cellar/grass-73/7.3.svn_src_snapshot_latest/grass-7.3.svn/etc/python/grass/script/core.py”, line 74, in init
subprocess.Popen.init(self, args, **kwargs)
File “/usr/local/Cellar/python/2.7.11/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py”, line 710, in init
errread, errwrite)
File “/usr/local/Cellar/python/2.7.11/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py”, line 1335, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
Can’t stop the signal.
