[GRASS-user] r.digit. no zoom/pan option while digitizing ?
Hello Everyone,
I was looking to create a raster mask by hand using r.digit module.
The geocoded map is large and zooming is essential. There’s no
zoom/pan option while digitizing. I have to zoom into part of the
raster map prior to running the module r.digit using d.zoom.
I have to exit the r.digit module after each segment of the mask is created.
And then reset region to fit the entire map. And then display the
mask created and then select the next region to be zoomed in.
Create many masks and then patch them using r.patch.
I have gone through the archives,
It says, One can't force a running r.digit program to change the region it uses
internally. So one could change the region stored in the WIND file
using g.region, but that won't affect r.digit.
Is there any other way to create a raster mask!
Regards
Nagesh
Nagesh,
me too I think that r.digit is not handy ; I suggest you to digitize
your mask contour with v.digit. Then you can generate the corresponding
raster map with v.to.rast, and apply r.mask to the latter.
Bye,
VB
Le mercredi 24 septembre 2008 à 11:27 +0530, Nagesh Bhatkar a écrit :
Hello Everyone,
The geocoded map is large and zooming is essential. There's no
created.
Regards
Nagesh
grass-user mailing list
grass-user@lists.osgeo.org
Hi Nagesh,
Options
1. use Qgis for digitisation and then save the finished product in a GRASS data set.
Qgis has many tools to help digitisation.
2. You may also use OpenJUMP, for digitisation but it can save the finished vector as a shapele which needs to be imported in GRASS.
I remember that a couple of years ago, this (Option 1) was in fact suggested to be by this list.
Ravi Kumar
— On Wed, 9/24/08, Nagesh Bhatkar bnagesh@nio.org wrote:
> From: Nagesh Bhatkar bnagesh@nio.org
> Subject: [GRASS-user] r.digit. no zoom/pan option while digitizing ?
> To: grass-user@lists.osgeo.org
> Date: Wednesday, September 24, 2008, 11:27 AM
> Hello Everyone,
> <br>> It says, One can't force a running r.digit program to change the region it uses<br>> internally. So one could change the region stored in the WIND file<br>> using g.region, but that won't affect r.digit.<br>> <br>> Is there any other way to create a raster mask!<br>> <br>> Regards<br>> Nagesh<br>> <br>>
> <br>> _______________________________________________<br>> grass-user mailing list<br>> grass-user@lists.osgeo.org<br>> http://lists.osgeo.org/mailman/listinfo/grass-user<br>> <br>>
