Hi all.
I'm testing r.drain, but I cannot get reasonable results over a dtm: the
line produced is always much too short, stopping where it seems it
should proceed. I exaggerated elevation (*100000), as suggested by the
manpage, but results were only slightly better.
Any suggestion?
Thanks.
http://www.faunalia.it/pc
Hi Paolo,
try to use r.fill.dir on the elevation map with ~3 - 4 runs before you
use r.drain.
Best regards
Soeren
2011/3/24 Paolo Cavallini <cavallini@faunalia.it>:
Hi all.
Any suggestion?
Thanks.
http://www.faunalia.it/pc_______________________________________________
grass-user mailing list
grass-user@lists.osgeo.org
Il giorno gio, 24/03/2011 alle 12.47 +0100, Soeren Gebbert ha scritto:
Hi Paolo,
use r.drain.
Thanks Soeren, that improved the results considerably.
It would be good to have an option to set the level of filling (by
recursion, if nothing better is available).
All the best.
