[GRASS-user] r.fillnulls in SRTM not worrking
Hello everybody,
in a raster DEM I want to get rid of the voids.
The raster DEM I received in downloading it as an SRTM hgt and importing it
with r.in.srtm.
Filling the voids with r.fillnulls now does not work; it always gives me the
error-message:
"Not sufficient points to interpolate. Maybe no hole(s) to fill in the current
map region?"
There are definitely holes in my SRTM and I think the procedure I am using is
very standard. Can anybody help me, because I really do not know what to
change, since everything seems so easy and straight forward.
Thank you very much in advance for the help
micha
___________________________________________________________
Telefonate ohne weitere Kosten vom PC zum PC: http://messenger.yahoo.de
On Mon, Aug 3, 2009 at 10:14 PM, Micha Neubauer<Micha.Neubauer@yahoo.de> wrote:
Hello everybody,
with r.in.srtm.
error-message:
map region?"
Please point us to the SRTM tile so that we can replicate the
problem.
Which GRASS version are you using on which operating system?
On 03/08/09 22:14, Micha Neubauer wrote:
Hello everybody,
The raster DEM I received in downloading it as an SRTM hgt and importing it with r.in.srtm.
Filling the voids with r.fillnulls now does not work; it always gives me the error-message:
"Not sufficient points to interpolate. Maybe no hole(s) to fill in the current map region?"
There are definitely holes in my SRTM and I think the procedure I am using is very standard. Can anybody help me, because I really do not know what to change, since everything seems so easy and straight forward.
Is your computational region adjusted to the srtm (g.region) ?
Moritz
Hello Markus and Moritz,
Thank you very much for answering! I am in Tanzania at the moment, so
unfotunately I could not relpy immediately because of the unreliable internet-
connection here...
But I am glad to say that I solved it!
@Markus you were right, I had the region set to EPSG:4326 in general. But you
have to set the region to the SRTM-File you want to use...
Thanks and
Greetings
micha
Der frühe Vogel fängt den Wurm. Hier gelangen Sie zum neuen Yahoo! Mail: http://mail.yahoo.de
