[GRASS-user] r.fuzzy.logic problem
I’m new with GRASS GIS and I’m interesting to learn the use of r.fuzzy.* tools. I read Jasiewicz paper (A new Grass GIS fuzzy inference system for massive data analys) and I run r.fuzzy.system tool without error. Now I’m trying to understand the process step by step using r.fuzzy.set and r.fuzzy.logic. I produced membership raster with r.fuzzy.set but when I use its outputs to run r.fuzzy.logic I have the follow error: ERROR: accum_abs_high_memb@PERMANENT is not of type CELL.
The tool requires two input raster data and both are FCELL. I have no idea where can be the error, both input data are from r.fuzzy.set.
I’m running Grass GIS 7.2.1 in Window 10 and I’m using spearfish60_grass7 maps.
Thanks in advance.
Paola
On 17/05/18 16:43, bonatopaola@libero.it wrote:
I'm new with GRASS GIS and I'm interesting to learn the use of r.fuzzy.* tools. I read Jasiewicz paper (A new Grass GIS fuzzy inference system for massive data analys) and I run r.fuzzy.system tool without error. Now I'm trying to understand the process step by step using r.fuzzy.set and r.fuzzy.logic. I produced membership raster with r.fuzzy.set but when I use its outputs to run r.fuzzy.logic I have the follow error: ERROR: <accum_abs_high_memb@PERMANENT> is not of type CELL.
I'm running Grass GIS 7.2.1 in Window 10 and I'm using spearfish60_grass7 maps.
AFAICT, the message about CELL was an typo (should be FCELL), and one of the FCELL types was ignored and the module fataled out in any case. Shows that you are probably the first one to use these modules in a long time...
I've tried to correct according to my understanding after a rapid reading of the code. Could you reinstall the module with g.extension and tell us if the error has been corrected ?
Moritz
time...
Sorry, just saw that you are on Windows: you will have to wait for the module to be recompiled to get the changes. The latest tomorrow...
Moritz
Il 17 maggio 2018 alle 17.06 Moritz Lennert mlennert@club.worldonline.be ha scritto:
time…
I’ve tried to correct according to my understanding after a rapid
module to be recompiled to get the changes. The latest tomorrow…
Moritz
Thank you Moritz,
I installed OsgeoLive virtual box with GRASS to run fuzzy tools also with Linux, so I’ll run r.fuzzy.logic there and I’ll tell you if it works.
Paola
time…
Moritz
Thank you Moritz,
Paola
Hi Moritz,
r.fuzzy.logic works!
Thank you,
Paola
