[GRASS-user] R-GDAL incompatible libraries
Greetings
I have just installed R, spgrass6, rgdal into my Ubuntun installation.
While I was running an example from GRASS book I got this error
precip30n ← readVECT6(“precip_30ynormals”, ignore.stderr=TRUE)
ERROR: Incompatible library version for module. You need to rebuild GRASS
or untangle multiple installations.
Where can I find an identification of the correct libraries versions.
Thank you
Kim
Kim Besson:
> precip30n <- readVECT6("precip_30ynormals", ignore.stderr=TRUE)
Thank you
Kim
Hi Kim!
Did you install grass from source? Did you install R, spgrass6 from
source?
- If you have installed grass from source, then try to rebuild grass
(after having installed R and the rest).
- If you have grass from the ubuntu repositories, the you should
probably stick with R and the rest from the repositories as well. If the
latter is the case and it does not work, then there is a problem.
Tell us a bit more...
Nikos
Hi
I have installed R from Ubuntu repositories. My grass installation is a Weekly snapshot.
I had to install rgdal since it doesn’t exist in UBUNTU repositories neither CRAN and the same with spgrass6.
Ok I will rebuild grass and reply again to mailing list
Thanks
Kim
source?
  • If you have installed grass from source, then try to rebuild grass
  • If you have grass from the ubuntu repositories, the you should
Tell us a bit more…
Nikos
Ok I have just installed latest GRASS snapshot and I got the following error
What I would like to know is the versions of R and spgrass6 that I should install on my system in order to not get this errors?
Thanks
Kim
2010/3/2 Kim Besson <kimbesson1981@gmail.com>
Hi
Thanks
Kim
source?
Tell us a bit more…
Nikos
Latest snapshot of grass65 or grass70?
Check the last posts in this thread:
-http://lists.osgeo.org/pipermail/grass-stats/2009-January/000899.html
and afterwards,
and perhaps:
-http://n2.nabble.com/error-Incompatible-library-version-for-module-You-need-to-rebuild-GRASS-or-untangle-multiple-install-td3347115.html
Maybe there is (still?) a problem with grass70... ? Not sure (since I
haven't been messing around for a while).
Nikos
2010/3/2 Kim Besson <kimbesson1981@gmail.com>:
You also need to update the GRASS-GDAL plugin.
Hi Kim
I am using R 9.2 (ubuntu repo),
grass6.5 (source), and grass6.4(ubuntugis) works too,
rgdal (source, not the lates thttp://cran.r-project.org/src/contrib/Archive/rgdal/rgdal_0.6-21.tar.gz ), and
spgrass6 (install.packages("spgras6") in R)
Hope it works
Leo Hardtke
Thanks
Kim
2010/3/2 Kim Besson <kimbesson1981@gmail.com <mailto:kimbesson1981@gmail.com>>
    Hi
    is a Weekly snapshot. I had to install rgdal since it doesn't exist in UBUNTU
    Thanks
    Kim
        source?
        grass
        well. If the
        Nikos
grass-user mailing list
grass-user@lists.osgeo.org
Ok I reinstalled rgdal
R CMD INSTALL rgdal
And then:
R
library(spgrass6)
Output:
Loading required package: sp
Loading required package: rgdal
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 1.5.4, released 2009/01/07
Path to GDAL shared files: /usr/share/gdal15
Loaded PROJ.4 runtime: Rel. 4.6.1, 21 August 2008
Path to PROJ.4 shared files: (autodetected)
Loading required package: XML
GRASS GIS interface loaded with GRASS version: 6.4.0svn
and location: North-Carolina
precip30 ← readVECT6(“precip_30ynormals”, ignore.stderr=TRUE)
Same error.I’m running GRASSsvn6.4.0, from latest week, in a Linux Machine with:
rgdal_0.6-10
spgrass6_0.6-15.
R version 2.9.2 (2009-08-24)
Any idea of what might not be compatible?
Thank you
Kim
2010/3/2 Markus Neteler <neteler@osgeo.org>
Kim…
I think you have to update gdal (1.6.3-2 in ubuntugis-unstable repo)
and maybe use grass 6.4rc5 (ubuntugis)
leo
library(spgrass6)
Loaded GDAL runtime: GDAL 1.6.3, released 2009/11/19
Path to GDAL shared files: /usr/share/gdal16
Loaded PROJ.4 runtime: Rel. 4.7.1, 23 September 2009
GRASS GIS interface loaded with GRASS version: 6.5.svn
and location: hardtke
Following Leo’s suggestion I installed GDAL 1.6.3 and I tried again:
library(spgrass6)
and location: nc_spm_08
(seems OK?)
precip ← readVECT6(“precip_30ynormals”, ignore.stderr)
OGR data source with driver: GRASS
Source: “/mnt/GIS/nc_spm_08/PERMANENT/vector/precip_30ynormals/head”, layer: “1”
with 136 features and 18 fields
Feature type: wkbPoint with 3 dimensions
(seems OK?)
When I did
plot(nc_state, axes=TRUE)
plot(precip30n, add=TRUE, lwd=2, col=“brown”)
Error: object ‘precip30n’ not found
Error in plot(precip30n, add = TRUE, lwd = 2, col = “brown”) :
error in evaluating the argument ‘x’ in selecting a method for function ‘plot’
THe last plot gave that error
But would you say that it seems to be working?
Thank you all for your help and support
Thanks
Kim
Question: Is there any known problem with GRASS and GDAL1.6.3?
R CMD INSTALL rgdal
And then:
R
library(spgrass6)
Output:
rgdal_0.6-10
spgrass6_0.6-15.
Thank you
Kim
Kim Besson wrote:
Following Leo's suggestion I installed GDAL 1.6.3 and I tried again:
library(spgrass6)
(seems OK?)
precip <- readVECT6("precip_30ynormals", ignore.stderr)
Source: "/mnt/GIS/nc_spm_08/PERMANENT/vector/precip_30ynormals/head", layer:
"1"
(seems OK?)
When I did
plot(precip30n, add=TRUE, lwd=2, col="brown")
Error: object 'precip30n' not found
Error in plot(precip30n, add = TRUE, lwd = 2, col = "brown") :
  error in evaluating the argument 'x' in selecting a method for function
'plot'
Thanks
Kim
Looks like a typo this time you put your value into precip and then
tried to call precip30n.
Alex
Kim
you have to plot the R object precip, not the grass vector precip30n
plot(precip,lwd=2, col=“brown”) should work!
Leo
EEHEHEHEEH You are absolutely right :slight_smile:
On Tue, Mar 2, 2010 at 5:58 PM, Leo Hardtke <leohardtke@gmail.com> wrote:
Kim
Leo
library(spgrass6)
(seems OK?)
(seems OK?)
When I did
Thanks
Kim
R CMD INSTALL rgdal
And then:
R
library(spgrass6)
Output:
rgdal_0.6-10
spgrass6_0.6-15.
Thank you
Kim
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user)
EHEHE this is true inglorious. Me and Gilbert were trying to compile and put this working and a simple typo was our final error.
Thanks. Now it’s working
See ya
Kim
