Dear GRASS-users,
I think my upcoming question is quiet basic but however I could not find a solution on my own so far. In GRASS you can export output tables via ">" to an external file. As I'm writing a script for data analysis in R using spgrass6-package I'd like also to get the table (for example from r.statistics, method=distribution) which is created in GRASS also as a table or at least as single numerical values in R.
I tried my best with the "intern=T" command in R to write the output to an R-object. That worked...However the values were then of class "character". So what I did was using strsplit and in this way cutting the object and using as.numerical. In the following step I created a table. However, it's not very straight-forward and I am sure that there is a "one command"-solution.
Thanks in advance for your help!
Tim
