[GRASS-user] r.hazard.flood extension
Dear users
I am new with Grass. I am trying to use the r.hazard.flood extension but I get the following error:
File “/home/lara/.grass7/addons/scripts/r.hazard.flood”, line 145, in
sys.exit(main())
File “/home/lara/.grass7/addons/scripts/r.hazard.flood”, line 78, in main
resolution = (float(dict_region[‘nsres’]) + float(dict_region[‘ewres’]))/2
ValueError: invalid literal for float(): 0:00:00.17656
Any idea of what can be wrong? my dem file (named fmosaic) is type raster, FCELL, 5099 rows 7647 columns, resolution: 0:00:00.17656
I thougth it was probably a problem with the dem resolution (5 m) but I tried with another DEM with different resolution and get the same error warning.
Hope to solve this!
Lara
Hi Lara,
as far as I remember, it worked only in projected coordinate system.
Hope this helps,
Kind regards,
Margherita Di Leo
Thanks Margherita ! you were right!
Kind regards,
Lara
El vie., 24 de may. de 2019 a la(s) 10:48, Margherita Di Leo (diregola@gmail.com) escribió:
Hi Lara,
Hope this helps,
Kind regards,
On Fri, May 24, 2019 at 3:41 PM Lara DC <dellaceca.lara@gmail.com> wrote:
Dear users
sys.exit(main())
Hope to solve this!
Lara
grass-user mailing list
grass-user@lists.osgeo.org
Margherita Di Leo
pá 24. 5. 2019 v 15:48 odesílatel Margherita Di Leo <diregola@gmail.com> napsal:
1) should be mentioned in manual at least
File "/home/lara/.grass7/addons/scripts/r.hazard.flood", line 145, in <module>
    sys.exit(main())
File "/home/lara/.grass7/addons/scripts/r.hazard.flood", line 78, in main
    resolution = (float(dict_region['nsres']) + float(dict_region['ewres']))/2
2) should faill more gracefully. LL location is not supported. Feel
free to open a ticket in trac.
Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Fri, May 24, 2019 at 6:36 PM Martin Landa <landa.martin@gmail.com> wrote:
+1 - TODO
>> sys.exit(main())
https://github.com/OSGeo/grass-addons/pull/4
  1. should be mentioned in manual at least
+1 - TODO
Done
sys.exit(main())
  1. should faill more gracefully. LL location is not supported.
Thank you Markus.
Margherita Di Leo
On Fri, Jun 7, 2019 at 10:44 AM Margherita Di Leo <diregola@gmail.com> wrote:
+1 - TODO
Done
sys.exit(main())
A simple solution would be
dict_region = grass.region()
instead of
info_region = grass.read_command(‘g.region’, flags = ‘p’)
dict_region = grass.parse_key_val(info_region, ‘:’)
but that does not solve the problem of resolution being in degrees. For ll, you would need to get the resolution for each raster row separately, or estimate with
r.mapcalc “ll_resolution = sqrt(area())”
which probably doesn’t make sense for higher latitudes.
Markus M
