[GRASS-user] r.hazard.flood
Am working on developing flood hazard map using the module r.hazard.flood. Whenever I try to run the module I get the following error
(Sun Mar 13 23:43:19 2016)
r.hazard.flood map=floodanalysis.alpha@edgar flood=flood mti=MTI
File “/home/edgar/.grass6/addons/r.hazard.flood”, line
145, in
sys.exit(main())
File “/home/edgar/.grass6/addons/r.hazard.flood”, line 80,
in main
resolution = (float(dict_region[‘nsres’]) +
float(dict_region[‘ewres’]))/2
ValueError: invalid literal for float(): 0:00:00.09
(Sun Mar 13 23:43:20 2016) Command finished (0 sec)
Please if I may get more help on how to use r.hazard.flood to produce flood hazard maps. thanks in advance
145, in
sys.exit(main())
in main
it looks like you are using it in an unprojected location (latitude-longitude),
try to reproject your data into a location with suitable projection.
However, the module should be able to deal with this somehow (either enable it or finish with appropriate error message), so you should create a ticket for this bug.
Best,
Anna
grass-user mailing list
grass-user@lists.osgeo.org
