[GRASS-user] r.horizon
Hello,
i’m new to grass and not shure if i’m missing something but using “r.horizon” with GRASS 6.4.0 on Windows 7 in the single point mode gives me the “Unable to set up lat/long projection parameters” error. Im using a astergdem (http://asterweb.jpl.nasa.gov/gdem.asp).
Command used:
r.horizon -d --verbose elevin=astadem@TEST_r_horizon horizonstep=1 coord=47.113697,11.310281 dist=0.7
g.region -p
projection: 3 (Längen- und Breitengrad)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 50:00:00.5N
south: 45:59:59.5N
west: 7:59:59.5E
east: 18:00:00.5E
nsres: 0:00:01
ewres: 0:00:01
rows: 14401
cols: 36001
cells: 518450401
g.proj -p
-PROJ_INFO-------------------------------------------------
proj : ll
datum : wgs84
ellps : wgs84
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : degree
units : degrees
meters : 1.0
The raster displays correctly when using d.rast and displays correct elevation values with r.what.
Same problem when projecting raster into utm coordinates or using a smaller region within the large dem.
Can’t find the problem. Can anybody help me?
Thanks a lot!
regards
Marc
2010/11/10 Marc Olefs <marc.olefs.info@gmail.com>:
i'm new to grass and not shure if i'm missing something but using
"r.horizon" with GRASS 6.4.0 on Windows 7 in the single point mode gives me
the "Unable to set up lat/long projection parameters" error. Im using a
the error refers to Proj.4 library. Recently I had similar problem,
solution was to upgrade Proj.4 library from SVN trunk.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
