Hello,
Using GRASS 7.2.1svn r70842 (Linux 64bit from today’s binary snapshot) and it seems the extent=region parameter of the r.import is just ignored. Tried from GUI, then from command line, first with multi band virtual raster, then with single JPEG2000 file (as in the example below), with and without the -n option. Is it a known bug, or does it work for someone, perhaps in some other version, or with other input formats? I tried to look in trac, but did not see anything. I am aware how I can clip the rasters after import, but it seemed one of the fine new features which would make the daily use a little more comfortable…
Tomas Brunclik
GRASS 7.2.1svn (utm33n):~ > r.import -o input=/home/tom/GISdata/DPZ/Chlorofyl-vzorkovani/2016-09-13_R122_S2A_samping_09-13/S2A_USER_PRD_MSIL2A_PDMC_20160915T151344_R122_V20160913T100022_20160913T100504.SAFE/GRANULE/S2A_USER_MSI_L2A_TL_SGS__20160913T170505_A006411_T33UWR_N02.04/IMG_DATA/R20m/S2A_USER_MSI_L2A_TL_SGS__20160913T170505_A006411_T33UWR_B04_20m.jp2 output=20160913_R122.3b extent=region
UPOZORNĚNÍ: Přeskakuje se kontrola kartografického zobrazení.
Proceeding with import of 1 raster bands...
Importing raster map <20160913_R122.3b>...
100%
GRASS 7.2.1svn (utm33n):~ > g.region -p
projection: 1 (UTM)
zone: 33
datum: wgs84
ellipsoid: a=6378137 es=0.00669438
north: 5569000
south: 5543320
west: 531260
east: 570320
nsres: 20
ewres: 20
rows: 1284
cols: 1953
cells: 2507652
GRASS 7.2.1svn (utm33n):~ > r.info map=20160913_R122.3b
| Map: 20160913_R122.3b Date: Thu Apr 6 20:27:43 2017 |
| Mapset: sentinel2test Login of Creator: tom |
| DataBase: /home/tom/GISdata/grass |
| Title: |
| Timestamp: none |
| Type of Map: raster Number of Categories: 0 |
| Data Type: CELL |
| Rows: 5490 |
| Columns: 5490 |
| Total Cells: 30140100 |
| Projection: UTM (zone 33) |
| N: 5600040 S: 5490240 Res: 20 |
| E: 609780 W: 499980 Res: 20 |
| Range of data: min = 1 max = 17010 |
| Data Description: |
| generated by r.in.gdal |
| Comments: |
| r.in.gdal -o -k input="/home/tom/GISdata/DPZ/Chlorofyl-vzorkovani/20\ |
| 16-09-13_R122_S2A_samping_09-13/S2A_USER_PRD_MSIL2A_PDMC_20160915T15\ |
| 1344_R122_V20160913T100022_20160913T100504.SAFE/GRANULE/S2A_USER_MSI\ |
| _L2A_TL_SGS__20160913T170505_A006411_T33UWR_N02.04/IMG_DATA/R20m/S2A\ |
| _USER_MSI_L2A_TL_SGS__20160913T170505_A006411_T33UWR_B04_20m.jp2" ou\ |
| tput="20160913_R122.3b" memory=300 offset=0 num_digits=0 |
