[GRASS-user] r.in.ascii - ERROR: Data conversion failed
I get the following error when trying to import a map with r.in.ascii:
ERROR: Data conversion failed at row 245, col 197
Since this error message is not very self-explanatory, anyone have idea on what can possibly be the problem?
To verify if the command works, I exported and then re-imported another map, and everything went smooth, therefore it must be something related to the map that I’m trying to import…
G6.4.3svn
Thanks for any hint.
Best regards,
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
Hi again,
I figured out that the problem in my map was the mismatch between the number of rows / cols given in the header and the actual number of rows/cols. It would be nice to add a hint that comes with the error, i.e. something like:
Please verify that the number of rows/cols given in the header matches with the actual number of rows/cols.
…or something like that.
Thanks and best regards.
On Mon, Apr 29, 2013 at 4:02 PM, Margherita Di Leo <diregola@gmail.com> wrote:
G6.4.3svn
Best regards,
Margherita DI LEO
Via Fermi, 2749
Best regards,
Margherita DI LEO
Via Fermi, 2749
