Hi Users,
Trying to import an 8.7gb (jpeg2000) image into Grass 7.4.1 64 bit. I get the error below. Tested the image in another OS GIS package and it opens without issue. Not sure why Grass wont import it.
Thanks everyone!
Paul Shapley
(Wed Jul 18 09:19:16 2018)
r.in.gdal -o input=J:\Spatial Data\Aerial\APGB_received_20180416\aerial_25cm.jp2 output=aerial_25cm_master memory=3000
Over-riding projection check
Importing 3 raster bands…
Importing raster map <aerial_25cm_master.red>…
ERROR 1: Marker is not compliant with its position
ERROR 1: opj_decode() failed
ERROR 1: J:\Spatial
Data\Aerial\APGB_received_20180416\aerial_25cm.jp2, band 1:
IReadBlock failed at X offset 0, Y offset 0
ERROR 1: GetBlockRef failed at X block offset 0, Y block
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
ERROR 1: J:\Spatial
offset 0
Please note that the data are left in inconsistent state and may be corrupted
(Wed Jul 18 09:19:40 2018) Command aborted (24 sec)
Paul J. Shapley MSc CGeog (GIS) FRGS
