[GRASS-user] r.in.gdal -f bug?
I'm not sure if this is a bug, but when I try:
  r.in.gdal -f (to list all formats) I get:
ERROR: Required parameter <input> not set:
     (Raster file to be imported).
ERROR: Required parameter <output> not set:
     (Name of output raster map).
Description:
  Import GDAL supported raster file into a binary raster map layer.
Usage:
  r.in.gdal [-oefk] input=string output=name [band=value]
    [target=string] [title="phrase"] [location=string]
Flags:
   -o Override projection (use location's projection)
   -e Extend location extents based on new dataset
   -f List supported formats then exit
   -k Keep band numbers instead of using band color names
Parameters:
      input Raster file to be imported
     output Name of output raster map
       band Band to select (default is all bands)
     target Name of location to read projection from for GCPs transformation
      title Title for resultant raster map
   location Name for new location to create
I would expect that -f should work without any input and output maps given and this should give the same output as gdal_translate --formats ?
I'm running grass on Cygwin (6.1-csv-8) and gdal_translate 1.2.3.0, released 2004/08/25
Wolfgang
PS: would it we possible for the next binary release for cygwin to compile gdal with ecw support? I really appreciate that someone provides the cygwin installation packages (as I don't know how to compile all on my self)!
It's a limitation of the parser; you need to give it dummy values:
r.in.gdal -f in=foo out=bar
You'll have to check the ecw software license and beg the package
maintainer directly.
Hamish
