[GRASS-user] r.in.gdal for importing categorical ArcGIS binary rasters
I tried to import an ArcGIS binary raster (corine land cover for the French territory) with three fields on each pixels (VALUE, COUNT and CODE_06) using the r.in.gdal command. The import works just fine, except that in the resulting raster, in GRASS, I only get one field, which seems to be the VALUE field (and not the CODE_06 field, which I am interested in, and which is a categorical field, although coded with integers).
Is there a way to produce a resulting raster with all the fields of the initial ArcGIS layer, or alternatively to choose one unique field? Also, is there a limitation on categorical fields. For instance, what if instead of integer corine land cover codes I have literal labels, i.e. levels of my categorical field coded with strings?
Cheers, Manuel
----------------0----0------
INRA - InfoSol
Centre de recherche d'Orléans
2163 Avenue de la Pomme de Pin
CS 40001 ARDON
45075 ORLEANS Cedex 2
tel : (33) (0)2 38 41 48 21
fax : (33) (0)2 38 41 78 69
[http://www.gissol.fr](http://www.gissol.fr)
----0----0------------------
Hi Manuel,
GRASS does not support multi-band rasters, so you'll have
to import each band as a separate raster map.
r.in.gdal has the "band=" option to specify a band number
to import.
Best,
Ben
On 12/02/14 17:05, manuel.martin wrote:
CODE_06) using the *r.in.gdal* command. The import works just fine,
integers).
Cheers, Manuel
INRA - InfoSol
CS 40001 ARDON
grass-user mailing list
grass-user@lists.osgeo.org
Dr. Benjamin Ducke, M.A.
{*} Geospatial Consultant
{*} GIS Developer
  benducke@fastmail.fm
Hi Ben,
Thanks for the reply. I tried with the band option but it looks like gdal does not detect the multiple fields as multiple bands :
GRASS 7.0.svn (lambert93):~ > r.in.gdal --o \
> input=/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/clc/clc06_250m \
> band=3 output=testclc
WARNING: Raster map <testclc> already exists and will be overwritten
WARNING: Datum <Not_specified_based_on_GRS_1980_ellipsoid> not recognised
          by GRASS and no parameters found
Projection of input dataset and current location appear to match
ERROR 5: /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/clc/clc06_250m: GDALDataset::GetRasterBand(3) - Illegal band #
ERROR: Selected band (3) does not exist
Cheers, Manuel
On 02/12/2014 08:25 PM, Benjamin Ducke wrote:
Hi Manuel,
to import.
Best,
Ben
integers).
Cheers, Manuel
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
Hmm, the manual page does not say so explicitely,
but maybe band numbering starts with "0"?
In that case your band 3 would have index number "2".
Ben
On 13/02/14 10:48, manuel.martin wrote:
Hi Ben,
ERROR 5:
Cheers, Manuel
Hi Manuel,
to import.
Best,
Ben
integers).
Cheers, Manuel
INRA - InfoSol
CS 40001 ARDON
{*} GIS Developer
I had already tried this (with "2") ;-). No luck either. Reading your email I tried with "0" (maybe would gdal detect only two bands over three). It comes out that only "band=1" works....
GRASS 7.0.svn (lambert93):~ > r.in.gdal --o input=/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/clc/clc06_250m band=0 output=testclc
ERROR 5: /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/clc/clc06_250m: GDALDataset::GetRasterBand(0) - Illegal band #
ERROR: Selected band (0) does not exist
Ben
Hi Ben,
ERROR 5:
Cheers, Manuel
Hi Manuel,
to import.
Best,
Ben
integers).
Cheers, Manuel
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
Ouch. I am beginning to suspect that the ESRI "field"
concept for raster layers does not translate well
to GRASS/GDAL. Sorry for not being able to help.
Maybe someone else on this list has experience with
this type of data structure?
At least now we know that r.in.gdal starts counting
bands with "1"!
Ben
ERROR 5:
Ben
Hi Ben,
recognised
ERROR 5:
Cheers, Manuel
Hi Manuel,
to import.
Best,
Ben
I am
integers).
the
Also,
Cheers, Manuel
INRA - InfoSol
CS 40001 ARDON
{*} GIS Developer
Out of the box:
Import it in R and save it as a Tiff - use GRASS to open this tiff. Maybe it works :stuck_out_tongue_winking_eye:
On 13 February 2014 10:50, Benjamin Ducke <benducke@fastmail.fm> wrote:
Ouch. I am beginning to suspect that the ESRI “field”
bands with “1”!
Ben
I had already tried this (with “2”) ;-). No luck either. Reading your
email I tried with “0” (maybe would gdal detect only two bands over
three). It comes out that only “band=1” works…
WARNING: Raster map already exists and will be overwritten
ERROR 5:
but maybe band numbering starts with “0”?
In that case your band 3 would have index number “2”.
Ben
Hi Ben,
recognised
ERROR 5:
Cheers, Manuel
Hi Manuel,
GRASS does not support multi-band rasters, so you’ll have
r.in.gdal has the “band=” option to specify a band number
to import.
Best,
Ben
I am
integers).
the
Also,
Cheers, Manuel
INRA - InfoSol
Centre de recherche d’Orléans
CS 40001 ARDON
{} Geospatial Consultant
} GIS Developer
Nuno César de Sá
+351 91 961 90 37
I think geoTiffs do not handle categorical variables (can anyone confirm?), neither the writeRAST6() function from spgrass6 (tested yesterday), and that's why I looked for a full GRASS option (avoiding using R to go from ArcGIS to GRASS). So it is true that I can import categorical ArcGIS binary rasters into R, but then I'm stuck into R and cannot move to GRASS...
Manuel
On 02/13/2014 11:58 AM, Nuno Sá wrote:
Out of the box:
On 13 February 2014 10:50, Benjamin Ducke <benducke@fastmail.fm <mailto:benducke@fastmail.fm>> wrote:
    bands with "1"!
    Ben
    > I had already tried this (with "2") ;-). No luck either. Reading
    your
    > email I tried with "0" (maybe would gdal detect only two bands over
    > three). It comes out that only "band=1" works....
    > GRASS 7.0.svn (lambert93):~ > r.in.gdal --o
    > band=0 output=testclc
    > WARNING: Raster map <testclc> already exists and will be overwritten
    > WARNING: Datum <Not_specified_based_on_GRS_1980_ellipsoid> not
    recognised
    > by GRASS and no parameters found
    > Projection of input dataset and current location appear to match
    > ERROR 5:
    > GDALDataset::GetRasterBand(0) - Illegal band #
    > ERROR: Selected band (0) does not exist
    > On 02/13/2014 10:59 AM, Benjamin Ducke wrote:
    >> Hmm, the manual page does not say so explicitely,
    >> but maybe band numbering starts with "0"?
    >> In that case your band 3 would have index number "2".
    >> Ben
    >> On 13/02/14 10:48, manuel.martin wrote:
    >>> Hi Ben,
    >>> Thanks for the reply. I tried with the band option but it
    looks like
    >>> gdal does not detect the multiple fields as multiple bands :
    >>> GRASS 7.0.svn (lambert93):~ > r.in.gdal --o \
    >>>> band=3 output=testclc
    >>> WARNING: Raster map <testclc> already exists and will be
    overwritten
    >>> WARNING: Datum <Not_specified_based_on_GRS_1980_ellipsoid> not
    >>> recognised
    >>> by GRASS and no parameters found
    >>> Projection of input dataset and current location appear to match
    >>> ERROR 5:
    >>> GDALDataset::GetRasterBand(3) - Illegal band #
    >>> ERROR: Selected band (3) does not exist
    >>> Cheers, Manuel
    >>> On 02/12/2014 08:25 PM, Benjamin Ducke wrote:
    >>>> Hi Manuel,
    >>>> GRASS does not support multi-band rasters, so you'll have
    >>>> to import each band as a separate raster map.
    >>>> r.in.gdal has the "band=" option to specify a band number
    >>>> to import.
    >>>> Best,
    >>>> Ben
    >>>> On 12/02/14 17:05, manuel.martin wrote:
    >>>>> Hi all,
    >>>>> I tried to import an ArcGIS binary raster (corine land cover
    for the
    >>>>> French territory) with three fields on each pixels (VALUE,
    COUNT and
    >>>>> CODE_06) using the *r.in.gdal* command. The import works
    just fine,
    >>>>> except that in the resulting raster, in GRASS, I only get
    one field,
    >>>>> which seems to be the VALUE field (and not the CODE_06
    field, which
    >>>>> I am
    >>>>> interested in, and which is a categorical field, although
    coded with
    >>>>> integers).
    >>>>> Is there a way to produce a resulting raster with all the
    fields of
    >>>>> the
    >>>>> initial ArcGIS layer, or alternatively to choose one unique
    field?
    >>>>> Also,
    >>>>> is there a limitation on categorical fields. For instance,
    what if
    >>>>> instead of integer corine land cover codes I have literal
    labels, i.e.
    >>>>> levels of my categorical field coded with strings?
    >>>>> Cheers, Manuel
    >>>>> ----------------0----0------
    >>>>> INRA - InfoSol
    >>>>> Centre de recherche d'Orléans
    >>>>> 2163 Avenue de la Pomme de Pin
    >>>>> CS 40001 ARDON
    >>>>> 45075 ORLEANS Cedex 2
    >>>>> tel : (33) (0)2 38 41 48 21
    >>>>> fax : (33) (0)2 38 41 78 69
    >>>>> http://www.gissol.fr
    >>>>> ----0----0------------------
    >>>>> _______________________________________________
    >>>>> grass-user mailing list
    >>>>> grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
    >>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
    {*} GIS Developer
Nuno César de Sá
+351 91 961 90 37
INRA - InfoSol
CS 40001 ARDON
AFAIU, your "categorical" variables are just integers, or ? So no problem to create a GeoTiff with them.
This said, what exactly is the format the data is in ? Is it really a binary with several values per pixel, or do you have one value per pixel and then a lookup table linking these values to clc categories ? ESRI's binary ArcInfo Grid format has a specific file (vat.adf for Value Attribute Table) which contains this lookup table, with a value and count field.
In GRASS, the equivalent would be labels linked to category values. But actually since the CLC categories are also integers, you could use those as category values and put the text descriptions into the labels.
The CLC data contains a legend which links values to categories:
http://www.eea.europa.eu/data-and-maps/data/corine-land-cover-2006-raster#tab-additional-information
see clc_legend.csv
Using that file and a bit of text handling magic you can easily create an input file for r.reclass to create a map with clc categories as values and the textual descriptions as labels.
Moritz
Manuel
Out of the box:
    bands with "1"!
    Ben
    your
    recognised
    > ERROR 5:
    >> Ben
    >>> Hi Ben,
    looks like
    overwritten
    >>> recognised
    >>> ERROR 5:
    >>> Cheers, Manuel
    >>>> Hi Manuel,
    >>>> to import.
    >>>> Best,
    >>>> Ben
    >>>>> Hi all,
    for the
    COUNT and
    just fine,
    one field,
    field, which
    >>>>> I am
    coded with
    >>>>> integers).
    fields of
    >>>>> the
    field?
    >>>>> Also,
    what if
    labels, i.e.
    {*} GIS Developer
Nuno César de Sá
+351 91 961 90 37
INRA - InfoSol
CS 40001 ARDON
Hi Moritz and thank you for the valuable informations. So I looked closer at the data and it is ESRI’s binary ArcInfo Grid format with vat.adf files in the layer directory. These tables may be accessed outside of ArcGIS using for instance gdalinfo, and the R raster library seem to do it as well. However these tables seem to contain some binary codes so they cannot easily be read from automatic processing. Unfortunately, CLC is not the only categorical layer I need to process, and manually linking the imported rasters values (within GRASS) to manually extracted codes (which again may be also strings) is not really an option. (or maybe is there a way to automate the process?) So I am now thinking to convert these ArcGIS layers to another format using the gdal library (function gdal_translate for instance) for latter importing these converted layers to grass. I am thus facing two new questions. 1) which format is the best suited for carrying such categorical data on larger rasters among supported gdal formats and 2) will this format be supported by grass? It seems to me that this story with multiple fields and categorical data might be related to the problem described here : Cheers, Manuel
yesterday), and that’s why I looked for a full GRASS option (avoiding
categorical ArcGIS binary rasters into R, but then I’m stuck into R and
cannot move to GRASS…
AFAIU, your “categorical” variables are just integers, or ? So no problem to create a GeoTiff with them.
This said, what exactly is the format the data is in ? Is it really a binary with several values per pixel, or do you have one value per pixel and then a lookup table linking these values to clc categories ? ESRI’s binary ArcInfo Grid format has a specific file (vat.adf for Value Attribute Table) which contains this lookup table, with a value and count field.
http://r-forge.r-project.org/forum/forum.php?thread_id=1689&forum_id=962
see clc_legend.csv
Moritz
Manuel
Out of the box:
bands with “1”!
Ben
your
recognised
ERROR 5:
Ben
Hi Ben,
looks like
overwritten
recognised
ERROR 5:
Cheers, Manuel
Hi Manuel,
to import.
Best,
Ben
for the
COUNT and
just fine,
one field,
field, which
I am
coded with
integers).
fields of
the
field?
Also,
what if
labels, i.e.
Cheers, Manuel
INRA - InfoSol
CS 40001 ARDON
grass-user@lists.osgeo.org mailto:grass-user@lists.osgeo.org
} GIS Developer
benducke@fastmail.fm mailto:benducke@fastmail.fm
Nuno César de Sá
+351 91 961 90 37
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
On 13/02/14 18:48, manuel.martin wrote:
So I looked closer at the data and it is ESRI's binary ArcInfo Grid
If you can export the information with gdalinfo, you should be able to treat it automatically to create the necessary input files for r.reclass or r.category. I don't have any sample files here, so I can't test for myself. If you want to send me a sample file, I can try to see what is possible.
BTW: I just added to the GRASS wiki page on Corine Land Cover [2] the input necessary for r.reclass to transform a raster with generic 0-255 categories to a raster with the CLC codes as categories and the description of each class as a label.
If you have access to ArcGIS, you can apparently export the raster data table [3]. You should then be able to input that table into r.reclass or r.category depending on your needs and on the data.
questions.
GRASS raster format does not store attributes for rasters (or maximum one in the form of labels). So if you want to store the information contained in several fields in an attribute table, you have to create as many raster maps as there are attributes (assuming that these attributes are numerical). So I think you best bet is to try to get the attribute data in text form and then extract from that the inputs to r.reclass/r.category.
Moritz
[1] http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Raster_dataset_attribute_tables/009t00000009000000/
[2] http://grasswiki.osgeo.org/wiki/CORINE_Land_Cover#Legend
On Wed, Feb 12, 2014 at 5:05 PM, manuel.martin
<manuel.martin@orleans.inra.fr> wrote:
r.in.gdal will soon support import of category labels such as those
stored in the CODE_06 field. You can then inspect the labels with
r.category. GDAL supports reading and writing of raster attribute
tables, so far only the color rules stored in a raster attribute table
are imported, but I plan to add import of labels to r.in.gdal. Note
that this applies only to GRASS 7.
Markus M
Cheers, Manuel
INRA - InfoSol
CS 40001 ARDON
Markus M
Good to hear that ;-). I will wait for the next release of r.in.gdal (meanwhile I did import clc vector layers with v.in.ogr and later managed the category labels with v.to.rast).
All the best, Manuel
Cheers, Manuel
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
On Fri, Feb 14, 2014 at 5:41 PM, manuel.martin
French
using
which
Markus M
Done in r59073.
Markus M
is
of
Cheers, Manuel
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
Hi, I just compiled grass r59073 and gave a try.
I could not get the attributes imported along with the raster, but maybe am I missing something from the new revision of r.in.gdal (although from the code it looks that the import of values from the attribute table should be automatic?).
Markus, I just sent you the ESRI layer I am trying to import, in case you would like to try as well.
Thank you in advance
Manuel
French
using
which
Markus M
Done in r59073.
Markus M
is
of
Cheers, Manuel
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
On Tue, Feb 18, 2014 at 11:43 AM, manuel.martin
automatic?).
Yes, r.in.gdal automatically imports whatever it finds as color tables
or attribute labels.
GDAL does not see an attribute table in the data you sent to me, thus
GRASS can not import any attributes. If there is really an attribute
table, it is not recognized by GDAL.
Markus M
Manuel
French
using
which
Markus M
Done in r59073.
Markus M
Also,
is
of
my
Cheers, Manuel
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
automatic?).
Then maybe this is a gdal problem : I'm saying this because through the command gdalinfo, it looks like gdal detects an attribute table (see below).
GRASS 7.0.svn (lambert93):~/tmp > gdalinfo /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4
Driver: AIG/Arc/Info Binary Grid
Files: /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4.aux.xml
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/hdr.adf
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/dblbnd.adf
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/w001001.adf
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/w001001x.adf
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/sta.adf
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/vat.adf
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/log
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/prj.adf
/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/metadata.xml
Size is 2504, 2089
Coordinate System is:
PROJCS["unnamed",
     GEOGCS["Unknown datum based upon the GRS 1980 ellipsoid",
         DATUM["Not_specified_based_on_GRS_1980_ellipsoid",
             SPHEROID["GRS 1980",6378137,298.257222101,
                 AUTHORITY["EPSG","7019"]],
             AUTHORITY["EPSG","6019"]],
         PRIMEM["Greenwich",0,
             AUTHORITY["EPSG","8901"]],
         UNIT["degree",0.0174532925199433,
             AUTHORITY["EPSG","9122"]],
         AUTHORITY["EPSG","4019"]],
     PROJECTION["Lambert_Conformal_Conic_2SP"],
     PARAMETER["standard_parallel_1",44],
     PARAMETER["standard_parallel_2",49],
     PARAMETER["latitude_of_origin",46.5],
     PARAMETER["central_meridian",3],
     PARAMETER["false_easting",700000],
     PARAMETER["false_northing",6600000],
     UNIT["METERS",1]]
Origin = (198837.500000000000000,6808087.500000000000000)
Pixel Size = (50.000000000000000,-50.000000000000000)
Corner Coordinates:
Upper Left ( 198837.500, 6808087.500) ( 3d45' 3.55"W, 48d10'48.77"N)
Lower Left ( 198837.500, 6703637.500) ( 3d37'59.07"W, 47d14'36.54"N)
Upper Right ( 324037.500, 6808087.500) ( 2d 4'11.49"W, 48d15'52.06"N)
Lower Right ( 324037.500, 6703637.500) ( 1d58'52.06"W, 47d19'34.69"N)
Center ( 261437.500, 6755862.500) ( 2d51'32.26"W, 47d45'23.95"N)
Band 1 Block=256x16 Type=Byte, ColorInterp=Undefined
   Description = test_lf4
   Min=1.000 Max=6.000
   NoData Value=255
<GDALRasterAttributeTable>
   <FieldDefn index="0">
     <Name>VALUE</Name>
     <Type>0</Type>
     <Usage>5</Usage>
   </FieldDefn>
   <FieldDefn index="1">
     <Name>COUNT</Name>
     <Type>0</Type>
     <Usage>1</Usage>
   </FieldDefn>
   <FieldDefn index="2">
     <Name>CLASS_NAME</Name>
     <Type>2</Type>
     <Usage>0</Usage>
   </FieldDefn>
   <Row index="0">
     <F>1</F>
     <F>1313166</F>
     <F>Valleys</F>
   </Row>
   <Row index="1">
     <F>2</F>
     <F>79933</F>
     <F>Lower Slopes</F>
   </Row>
   <Row index="2">
     <F>3</F>
     <F>110782</F>
     <F>Gentle Slopes</F>
   </Row>
   <Row index="3">
     <F>4</F>
     <F>42435</F>
     <F>Steep Slopes</F>
   </Row>
   <Row index="4">
     <F>5</F>
     <F>69408</F>
     <F>Upper Slopes</F>
   </Row>
   <Row index="5">
     <F>6</F>
     <F>1341719</F>
     <F>Ridges</F>
   </Row>
</GDALRasterAttributeTable>
Markus M
Manuel
French
using
which
Markus M
Done in r59073.
Markus M
Also,
is
of
my
Cheers, Manuel
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
On Tue, Feb 18, 2014 at 1:14 PM, manuel.martin
am
be
automatic?).
Files:
This file is missing in the archive you sent:
I am pretty sure that it contains the raster attribute table.
Markus M
Size is 2504, 2089
PROJCS["unnamed",
    UNIT["METERS",1]]
Corner Coordinates:
  Min=1.000 Max=6.000
  NoData Value=255
    <Name>VALUE</Name>
    <Type>0</Type>
    <Usage>5</Usage>
  </FieldDefn>
    <Name>COUNT</Name>
    <Type>0</Type>
    <Usage>1</Usage>
  </FieldDefn>
    <Type>2</Type>
    <Usage>0</Usage>
  </FieldDefn>
  <Row index="0">
    <F>1</F>
    <F>1313166</F>
    <F>Valleys</F>
  </Row>
  <Row index="1">
    <F>2</F>
    <F>79933</F>
    <F>Lower Slopes</F>
  </Row>
  <Row index="2">
    <F>3</F>
    <F>110782</F>
  </Row>
  <Row index="3">
    <F>4</F>
    <F>42435</F>
    <F>Steep Slopes</F>
  </Row>
  <Row index="4">
    <F>5</F>
    <F>69408</F>
    <F>Upper Slopes</F>
  </Row>
  <Row index="5">
    <F>6</F>
    <F>1341719</F>
    <F>Ridges</F>
  </Row>
Markus M
Manuel
French
CODE_06)
using
the
which
Markus M
Done in r59073.
Markus M
managed
the
Also,
is
instead
of
my
Cheers, Manuel
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
am
be
automatic?).
Files:
Markus M
Sorry about that, I just sent the landforms/test_lf4.aux.xml to you, but unfortunately it does not seem to contain the raster attribute table...:
GRASS 7.0.svn (lambert93):~/tmp > more /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4.aux.xml
<PAMDataset>
<SRS>PROJCS[&quot;RGF_1993_Lambert_93&quot;,GEOGCS[&quot;GCS_RGF_1993&quot;,DATUM[&quot;Reseau_Geodesique_Francais_1993&quot;,SPHEROID[&quot;GRS_1980&quot;,63
78137.0,298.257222101]],PRIMEM[&quot;Greenwich&quot;,0.0],UNIT[&quot;Degree&quot;,0.0174532925199433]],PROJECTION[&quot;Lambert_Conformal_Conic_2SP&quot;],PARAM
ETER[&quot;False_Easting&quot;,700000.0],PARAMETER[&quot;False_Northing&quot;,6600000.0],PARAMETER[&quot;Central_Meridian&quot;,3.0],PARAMETER[&quot;Standard_Pa
rallel_1&quot;,44.0],PARAMETER[&quot;Standard_Parallel_2&quot;,49.0],PARAMETER[&quot;Latitude_Of_Origin&quot;,46.5],UNIT[&quot;Meter&quot;,1.0]]</SRS>
   <PAMRasterBand band="1">
     <Description>test_lf4</Description>
     <Histograms>
       <HistItem>
         <HistMin>1</HistMin>
         <HistMax>6</HistMax>
         <BucketCount>256</BucketCount>
         <IncludeOutOfRange>1</IncludeOutOfRange>
         <Approximate>0</Approximate>
<HistCounts>1313166|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|79933|0|0|0|0|0|0|0|0|0|0|0|0|0|
0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|110782|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0
|0|0|0|0|0|0|0|0|0|0|42435|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|69408|0|0|0|0|0|0|0|0|0|0|0|0|0|0
|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|1341719</HistCounts>
       </HistItem>
     </Histograms>
   </PAMRasterBand>
</PAMDataset>
Size is 2504, 2089
PROJCS["unnamed",
     UNIT["METERS",1]]
Corner Coordinates:
   Min=1.000 Max=6.000
   NoData Value=255
     <Name>VALUE</Name>
     <Type>0</Type>
     <Usage>5</Usage>
   </FieldDefn>
     <Name>COUNT</Name>
     <Type>0</Type>
     <Usage>1</Usage>
   </FieldDefn>
     <Type>2</Type>
     <Usage>0</Usage>
   </FieldDefn>
   <Row index="0">
     <F>1</F>
     <F>1313166</F>
     <F>Valleys</F>
   </Row>
   <Row index="1">
     <F>2</F>
     <F>79933</F>
     <F>Lower Slopes</F>
   </Row>
   <Row index="2">
     <F>3</F>
     <F>110782</F>
   </Row>
   <Row index="3">
     <F>4</F>
     <F>42435</F>
     <F>Steep Slopes</F>
   </Row>
   <Row index="4">
     <F>5</F>
     <F>69408</F>
     <F>Upper Slopes</F>
   </Row>
   <Row index="5">
     <F>6</F>
     <F>1341719</F>
     <F>Ridges</F>
   </Row>
Markus M
Manuel
French
CODE_06)
using
the
which
Markus M
Done in r59073.
Markus M
managed
the
Also,
is
instead
of
my
Cheers, Manuel
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
On Tue, Feb 18, 2014 at 2:09 PM, manuel.martin
maybe
am
the
be
automatic?).
you
below).
Files:
Markus M
Right. Unfortunately I can not reproduce the gdalinfo output you sent
previously, and as long as gdal does not see an attribute table, GRASS
can not import the labels in the attribute table. I use gdal 1.10.1,
if that helps.
Markus M
<PAMDataset>
    <Histograms>
      <HistItem>
      </HistItem>
    </Histograms>
  </PAMRasterBand>
</PAMDataset>
Size is 2504, 2089
PROJCS["unnamed",
     UNIT["METERS",1]]
Corner Coordinates:
   Min=1.000 Max=6.000
   NoData Value=255
     <Name>VALUE</Name>
     <Type>0</Type>
     <Usage>5</Usage>
   </FieldDefn>
     <Name>COUNT</Name>
     <Type>0</Type>
     <Usage>1</Usage>
   </FieldDefn>
     <Type>2</Type>
     <Usage>0</Usage>
   </FieldDefn>
   <Row index="0">
     <F>1</F>
     <F>1313166</F>
     <F>Valleys</F>
   </Row>
   <Row index="1">
     <F>2</F>
     <F>79933</F>
     <F>Lower Slopes</F>
   </Row>
   <Row index="2">
     <F>3</F>
     <F>110782</F>
   </Row>
   <Row index="3">
     <F>4</F>
     <F>42435</F>
     <F>Steep Slopes</F>
   </Row>
   <Row index="4">
     <F>5</F>
     <F>69408</F>
     <F>Upper Slopes</F>
   </Row>
   <Row index="5">
     <F>6</F>
     <F>1341719</F>
     <F>Ridges</F>
   </Row>
Markus M
Manuel
the
French
CODE_06)
using
the
the
and
which
table
Markus M
Done in r59073.
Markus M
managed
the
Also,
is
instead
of
of
my
Cheers, Manuel
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
